JMB RetrofitsVolks Autos
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,062
    Low temperatures and air con
    Just curious really. On other cars I have owned the aircon won't turn on if the temperature is less than a certain amount, say 5C. I believe this is to stop the compressor freezing. On the Audi I think this would be equivalent to not being able to turn off Econ mode. However it doesn't stop you. So what's going on?
    1. They solved this problem
    2. You're expected to be a grown up and do this yourself if the temp is low
    Anyone know?
    Oct 2013
    367
    Maybe the light is illuminated but nothing is happening the other end, so you think all is normal?
    Its the same on hgvs cant remember the cut of temp but 5degc does sound about right
  1. Alternator and air-con belt renwal
    By Miller in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2009, 22:22
  2. Doubla din and air con
    By sherry in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th April 2008, 12:33
  3. Engine Temp Dial - AND Air Con Problem
    By A13X-A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2007, 20:38
  4. 2 questions: ball joint and air con
    By nky_84 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th June 2006, 09:29
  5. Intermittent start Problem and Air con gas.
    By imported_Astwell in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th September 2004, 20:23
