JMB RetrofitsAH Fabrications
Results 1 to 15 of 15
    Oct 2012
    aberdeen
    120
    S4 Auto to manual conversion
    Ive been wondering if any one has any knowledge of this type of conversion being carried out
    the thought has crossed my mind as i have been getting a bit fed up of the tip tronic auto in my car
    I once carried out a conversion from auto to manual on a nissan 200sx which was pretty easy
    Growing old is madetory, Growing up is optional !
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    551
    Add GeoffDunk on Facebook
    From what I have learnt recently about my manual S4 I would guess there is differences in the Quattro system as the oil is different between manual and auto rear differentials ( a minor point) which leads me to think there are certain differences.
    I am by no means and expert on the subject but your Nissan would have been 2WD I assume?
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    Jul 2012
    56
    Just at a guess i recon you'll need to swap the rear diff as well and maybe the ECU or get the auto side of it mapped out so no faults are displayed.
    Along with the obvious trans tunnel, centre console and bulk head mods.
    Oct 2012
    aberdeen
    120
    with a whole donor S4 would there be differneces between the B7 & B6 model to do this swap
    usual items brake and clutch peddle, gear stick and centre consoul, the prop would need done and likley the diff, if the diff was not changed it would affect the cars acceleration and top speed
    also as mentioned the auto ecu would prob need switched off or removed, the main ECU would need some sort of bypass for the park/start
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    Kind of defeats the point of the conversion, but would it not be better just to sell your existing car and buying one with a manual gearbox? To me it seems very expensive and time consuming, but then projects are more rewarding and interesting, these modern Audis are harder to chop and change than my old Series IIa Land Rover .
    2008 A5 3.0TDI
    tut_gareth's Avatar
    Oct 2012
    Surrey, UK
    81
    From memory some research I did for a manual S6 a while ago, you would need gearbox, clutch and flywheel adapted from a V6, rear diff, brake servo, pedal box assembly, engine ecu, modification to wiring looms and ecu, recoding ignition engine gearbox and alarm system as they are all connected, plus other things I'm sure..... A lot more work than expected and probably cheaper / less hassle to fid a manual S4. Though of you do go ahead a build thread would make great reading
    ASC
    ASC's Avatar
    May 2010
    Aberdeenshire
    104
    Dude, if you can wait till next year I'll sell you mine!?
    2006 Sprint Blue S4 Avant - 2.5" catless DP's - Miltek Non Res cat back - BMC panel filter - JHM remap - H&R springs - EBC TG discs - Yellow stuff pads - Matt/Polished RS4's
    Oct 2012
    aberdeen
    120
    not keen on the avant like, you planning on selling up next year then ?
    ASC
    ASC's Avatar
    May 2010
    Aberdeenshire
    104
    Think so.. Hardly use it, spent a *** fortune on it too.. Would like to keep it but.. Should get out for a blast soon eh?
    Oct 2012
    aberdeen
    120
    aye need to get out for a blast before tha bad weather sets in like!
    tell ya you will end up regretting selling it if you do its one of that cars that you will wish you still had every time you see one
    ASC
    ASC's Avatar
    May 2010
    Aberdeenshire
    104
    I know, it's a tough decision but I've already kept it 1 year longer than planned.. I'll put it through its MOT in March and then see what happens.
    Looks like a possible SRS meet in December, might go along or maybe just meet up local sometime if you want. You still need to witness this thing now it's mapped..
    Oct 2012
    aberdeen
    120
    What you up to this weekend then?
    Jul 2007
    London
    3,235
    If you're in the market for a nice v8 s4 then i have a 2003 saloon which i will put up for sale in a few weeks !
    FOR SALE:
    Oct 2012
    aberdeen
    120
    Quote Originally Posted by adamss24 View Post
    its got to be the B7 if i was buying one, i wouldnt buy one just to break unless it was damaged
    ASC
    ASC's Avatar
    May 2010
    Aberdeenshire
    104
    Quote Originally Posted by Boombastik View Post
    Could maybe manage something tomorrow morning? Busy in the afternoon and away Sunday..
  1. Auto to manual conversion on 2.5v6 tdi quattro
    By Yappy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st November 2012, 09:53
  2. Multitronic --> Manual Conversion
    By donsajid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2012, 01:58
  3. Auto dimming Mirror conversion
    By unikarl in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st October 2010, 19:39
  4. Auto Lights/Wipers v Manual Lights/Wipers
    By A3_SSS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2009, 13:32
  5. Want an A6 Avant 1.9 tdi - Manual or Auto ??
    By Jetcat in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd April 2008, 12:56
