Volks AutosBadger5
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Broken Byzan
Thread: Hi i have an interesting problem
    Jan 2011
    48
    I have a 2005 55 plate 1.8t cab > when i brought it i had the Rac do there 300 plus point check and they cam back with the engine number BFB etc i've had audi change the cambelt and water pump over the 3 years i've had the car also 3 other gargaes have worked on it fixing one thing or another had a a broken hose replace rocker cover replaced(turned out they just stuck bits back together and cause a small oil leak!) battey plus starter motor. Now i've taken it to a gargae to fix the oil leak hense why i found out it was stuck last time! and they say when ordering a hose they couldnt find the right one as the engine is from a 1998 audi 1.8t???? with an engine code AEB now either the Rac are wrong and i would have never brought the car or something funny is going on ? At no time has someone swapped the engine out!!?? surely it wouldnt be worth the effort !?
    Let me know your thougts i'm going to call the rac and see what they say
    thanks
    Martin
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    it could have been changed for the AEB
    RAC wouldnt have looked at the number there lazy they will have just looked up up from the vin
    so yes you may have got a AEB lump in there
    only way to check is find the engine number on the engine itself.
    ukphillad's Avatar
    Jun 2013
    Dublin, Ireland
    108
    It's possible that the engine was replaced. Whenever you get RAC or any other company perform a check on a car, they won't go as far as checking the engine code. As bez101 said, only way is to check the number yourself, but don't rule out the possibility of a swap.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by mjsummer View Post
    thanks
    Martin
    What does the car's data sticker say? The engine code on the data sticker will be for the engine it left the factory with. So, if it hasn't been changed, then that should be what you have. But at Bez says, the only way to be 100% certain is to check on the engine itself.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    bez101's Avatar
    Jul 2008
    8,480
    the 2005 18T is normaly a BFB iv never seen one with a AEB lump fitted
    did you ask the garage how they know its an AEB ?
    Jan 2011
    48
    Well i have the document sent from the rac printed BFB etc and if they had said it was a 1998 AEB engine in the car i wouldnt have brought it!
    Thanks for the info guys
    bez101's Avatar
    Jul 2008
    8,480
    as i said above they wont look at the engine code
    they will only look at the sticked etc or v5 or computer checks
    dpaz's Avatar
    Oct 2011
    Lincolnshire
    331
    Those RAC checks aren't really worth the paper they're written on as they typically include significant disclaimers along the lines of "The information provided in is limited to the information stored on the DVLA database" or similar caveats.
    Nonetheless a disclaimer remove the threat of negligence, so if its significantly devalued the car it might be worth taking them to the small claims court.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    the engine is a completely different style if it's AEB, id have thought even a blind spaniel RAC man would spot one of them bodged in.
    It's just likely that an AEB part is still fitted on later A4's
    Easy check, is the water pump external to the block? Where is the aircon pump mounted?
    NHN likes this.
    bez101's Avatar
    Jul 2008
    8,480
    the blind rac blokes
    told me the clutch or my escort cosworth wasnt a cable
    and insisted on sticking it on a dolly for a 70 mile recovery
    even tho he told me he worked for ford for 17 years as a top mech
    bez101's Avatar
    Jul 2008
    8,480
    good idea post a picture up
  1. What diesels have the turbo problems?
    By APL TDi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd June 2009, 11:24
  2. Car back but I have a boost problem
    By docurley in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2008, 13:20
  3. i might have a turbo problem?i need some help
    By 97_A4_1.8Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2008, 14:08
  4. Do you have a dashpod problem??
    By S3 ROCKS in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2007, 19:55
  5. RS6 Alloys seem to have caused a problem
    By 5hake5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th August 2006, 17:02
