Chris NottVolks Autos
Results 1 to 8 of 8
    Aug 2013
    Surrey
    135
    3.0 TDi inlet runner flaps
    Evening all,
    i am looking at replacing the pair on a customers car, the inlet manifolds that is as both banks are flagging up the EML. I can get them from TPS but I want to keep the costs down, does anyone know if they are available anywhere else? I have seen on eBay a company sends you a pair from Germany and refunds you £60 for your old units, has anyone done that? what have you done.
    thanks
    kite's Avatar
    Oct 2007
    East Berks
    675
    Audi sell a repair kit for manifold runners.
    A4 (b6) 2.5 TDi QS Saloon.
    Aug 2013
    Surrey
    135
    Is that the kit that contains the linkage that connects the motor to the runners or is it the guides too that the runner sits in?
    27,099
    Why would you go to all this trouble if its for a clients car, surely fitting new local parts is the best option for them, really don't see the logic tbh, you want to minimise your risks & trouble for the client, not create potential headaches for them & you.
    Aug 2013
    Surrey
    135
    I understand what you are saying, it's a private job for a trader, so he wants to keep the costs down and I'm not prepared to fit a repair kit but rather a whole manifold. Has anyone tried the ones from Germany?
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    I used a £30 repair kit on both sides, it fixed bank 1 but I ended up getting a referbed manifold from Germany to fix bank 2, think it was £250 and fixed it. I have since done about 1500 miles with no issues, reasonably easy to fit. I did it to keep costs down. It had modified actuator rods on it so hopefully it will be good for another 100k miles. As NHN says, if its not your car, new parts might be the way to go, I only did it as it was my car and me fitting it myself.
    2008 A5 3.0TDI
    Jun 2011
    138
    if its running ok but just flagging the fault codes and engine light why not get them coded out? these guys do it FR&RTuning: MAHA Dyno Tuning: ECU, DSG Remapping looks like common faults
    012597 - Intake Manifold Runner Control - P3135 - 001 - Lower Stop not Reached.
    004120 - Intake Manifold Runner (Bank 2) - P1018 - 001 - Lower limit not reached.
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Aug 2013
    Surrey
    135
    Thanks for all they replies. Haven't thought about mapping them out , although I would prefer to change them probably going to get a pair from eBay from Germany and see how they go.
  1. A6 2.0 Tdi Inlet manifold actuator
    By JimC64 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 21st January 2013, 14:02
  2. Inlet manifold flap motor and Cooling fans eml fault code
    By dawudbhai in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th December 2012, 19:02
  3. TDI Inlet mani cleaning Question
    By bez101 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th August 2012, 20:57
  4. Help! Don't want to get ripped off, Inlet Manifold Flap Linkage broken!
    By MOOD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th January 2011, 15:35
  5. **HELP** inlet manifold flap throttle body
    By audi_a3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th October 2010, 09:36
