AH FabricationsVolks Autos
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Molnboman
Thread: 1.8T Quattro Avant MPG
    Sep 2009
    45
    My recently purchased 1.8T Quattro avant seems to be a bit thirsty.
    I filled the tank and im almost down to 3/4 tank and its covered just 50 miles of town driving.
    The exhaust was blowing a little when I got it which is now fixed so that might be a factor.
    26,716
    Maf maybe signalling wrong, worth a punt, has it had anything done off late?
    Sep 2009
    45
    Had a full scan today using Snap-on verdict and no fault codes.
    Dont think MAF gives a code anyway?
    How can I test the MAF
    Molnboman's Avatar
    Hej, if you still can't find obvious fault codes may be worth signing up to Fuelly.com to measure your approx' fuel consumption to settle your anxiety. Must say my 2.0t is very thirsty in town driving, dramatically so, compared to when it's up and cruising on main roads and motorways. Just don't seem to like crawling about in town.
    BR
    A
    Sep 2009
    45
    My M5 does approx 200 miles from a 80 litre tank.
    The A4 will do the same but from a smaller tank if things dont improve.
    How can I test the MAF?
    Molnboman's Avatar
    When you say town driving ...are you literally talking crawling 30mph stuff. You should be getting a lot more than that from a 1.8t one would think even in urban driving.
    Have you ran it for fault codes yet?..you'll need a friendly garage or a Mate with VAG job.
    Keep us updated.
    BR
    A
    Oct 2013
    Kent
    12
    old way to test maf was to unplug it and then drive it, if better its duff, if worse its okay
    Sep 2011
    69
    these cars arent great on fuel it must be said,, when i was tracking mine on fuelley i rareley got up to 30mpg so i stopped tracking it!!
    Molnboman's Avatar
    Quote Originally Posted by olly quattro View Post
    Just converted my Fuelly figures to UK and am getting 38'ish and I have FWD. 30 I would say is about right for 4wd. I had a Rav4 Petrol and the consumption on that was horrendous compared to my Audi. The price you pay for traction I guess.
    BR
    A
    olly quattro likes this.
    Mar 2011
    Truro, Cornwall
    62
    My b6tqs does 33mpg on a run and as stated alot less around town. My readings are from the dis tho so not spot on accurate. It is a heavy car tho with a small engine so not gonna be great. A remap may help slightly.
    Sep 2009
    45
    No fault codes using Snap-on diagnostics.
    Snap-on machine has facility to test components including MAF.
    Anyone done this?
    If so what should the parameteres/figures be on a MAF that is working properly??
    Sep 2009
    45
    OK I think I might have got to the bottom of things.
    Advisory by Audi on last service shows "Fuel injector O ring leaking"
  1. A6 Quattro avante 2.5 tdi auto MPG
    By Keggers in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th November 2012, 17:41
  2. B6 A4 1.9 TDI Avant - MPG for Quattro vs Non-Quattro?
    By Addie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th July 2011, 22:03
  3. A4 110 TDI Quattro Avant, cost of owning?
    By steve5s in forum Diesel forum
    Last Post: 14th December 2004, 15:56
  4. New member S-line Quattro Avant
    By imported_bubstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th July 2004, 11:03
  5. 2.8 Quattro Avant Chipping
    By EvilTad in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th June 2004, 19:20
