Sky InsuranceChris Nott
    Sep 2009
    45
    Audi paintwork/corrosion warranty
    How long is the Audi anti corrosion warranty?
    My 2006 Avant has slight bubbling appearing on the front arches.
    MK5 VW Golf has 12 Years-is Audi the same?
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    202
    10 years when I had some work done on my A3, they will do paint depth tests to see if its original paint. if it has been repaired at some point then they will not fit the bill for repair work.
    2008 A5 3.0TDI
    Sep 2009
    45
    Quote Originally Posted by ben.w93 View Post
    Yes I am aware of them checking the paint with a depth gauge to ascertain if its original.
    craigcull's Avatar
    Oct 2011
    Leeds uk
    1,004
    Visit craigcull's Youtube Channel
    13 years corrosion warranty on vw audi seat and skoda. Aslong as there is no outside influence e,g a chip thats bare metal resulting in corrosion. they usually authorise repair pending the paint depth being correct as above.
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    202
    Thinking about it, my A3 was a 2000 car and I went to Audi with it in 2012, so its definitely over 10 years old and they authorized my work too .
    2008 A5 3.0TDI
    craigcull's Avatar
    Oct 2011
    Leeds uk
    1,004
    Apologies its 12 years not 13. Just checked at work.
  1. Corrosion warranty with Audi
    By SinghB7 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th September 2013, 10:23
  2. Audi corrosion warranty? The dreaded brown stuff!
    By Dan320is in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2012, 17:04
  3. Audi's so called 12 year corrosion warranty
    By stevenbeedie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th April 2011, 23:51
  4. Audi Corrosion Warranty help...
    By Englishguy in forum Detailing
    Last Post: 14th May 2009, 10:38
  5. *Update* Audi 12 year Anti-Corrosion Warranty.
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2007, 13:47
