EM TuningSky Insurance
Results 1 to 9 of 9
Thread: Steamy Windows!
    Sep 2009
    45
    Steamy Windows!
    My 2006 Avant seems to stream up a lot especially when I put the heaters on?
    Is this the blocked scuttle drains that are common on Passat and A4 causing the problem or something else?
    Jun 2011
    Great Melton Norfolk
    1,346
    have you replaced pollen filter? They get full of muck and damp as well and cause bad ventilation.
    Sep 2009
    45
    No sir but the car was serviced at Audi this year. Dont know if pollen filter is routine service item as it is with BMWs.
    Where is it located?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by Mazi View Post
    it's in the plenum chamber, just to the right of the battery when looking from the front of the car. Just remove the plastic cover, pull the filter out and Bob's your uncle. Incidentally, even though they're not mega expensive, you might be able to clean it rather than buy a new one. I left mine soaking a bowl full of hot water and washing powder for a hour or so, then scrubbed it out with an old toothbrush.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Sep 2013
    63
    Quote Originally Posted by jdp1962 View Post
    Need to change mine myself, though what i tend to do after installing pollen filter is a bowl of uncooked rice left for 24 hours to absorb any remaining moisture inside your car either passenger or driver side. Make sure when seating the pollen cover back on it is properly seated as moisture will come in.
    As mentioned there not expensive, depending on if you want paper or charcoal filter the price varies.
    If you use glass cleaner and polish stops the misting a good bit i found.
    Sep 2009
    45
    My mate said I need to clean the scuttle drains also as these can be a problem on VAGs of this era.
    I might as well do that at the same time
    Do we have guide on the forum anywhere?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    easy job remove battery and remove the 2 gromets
    job done
    Sep 2013
    63
    job done
    is the battery not bolted in with a torx on the battery bracket clamp, im near sure it is?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    Quote Originally Posted by etxeondo View Post
    Yes it is.
  1. Steamy windows, heater matrix, air con...
    By adbett in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2010, 09:47
  2. steamy windows (jojo please read)
    By jonny87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2010, 23:47
  3. Steamy Windows
    By jojo in forum Detailing
    Last Post: 22nd February 2010, 14:25
  4. Really bad Steamy Windows!
    By Aprisa in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th December 2008, 07:15
  5. steamy windows
    By axelfols in forum A8/S8 forum
    Last Post: 13th February 2005, 22:17
