Chris NottVolks Autos
    Nagasaki's Avatar
    Aug 2012
    Henley on Thames
    24
    WMI install this weekend
    Our A4 cabriolet is off to have a Devils Own WMI fitted this weekend and wondered if anyone knew whether the knock sensor will automatically retard the timing due to the higher octane of the fuel going in and bump up the power slightly without a remap?
    Currently Revo stage 2 but has dreadful heat soak as running original smic.
    WMI is to cool it down and keep the insides clean.
    A4 1.8t B7 Cabriolet - Revo stage 2 map - Milltek Hi. Flow cat and system - Water Methanol injection - Forge valve - Brembo brakes with braided lines - Bilstein B12 Pro suspension kit - Air freshener
    Nagasaki's Avatar
    Aug 2012
    Henley on Thames
    24
    Returned from having the Devils Own WMI system fitted this afternoon.
    Firstly a big thank you to Alfie for fitting it today. Great, tidy job! Will post some pics when it's light.
    Excellent results. Some spirited driving for a couple of hours on the way back and the car just pulls constantly without becoming bogged down with heat soak.
    I have no idea whether the timings is advancing due to water/methanol mixture but it is certainly keeping it cool enough to feel like it previously had on the odd cold morning, but now it is lively all the time.
    Will be taking back to my local Revo tuner to see if we can now increase boost further given that there is no heat issues or risk of detonation (I think as not an expert)
    Would recommend though.
    Just need to source a decent large volume supplier of Methanol as you can empty the container quickly if you really try hard.
    Nagasaki's Avatar
    Aug 2012
    Henley on Thames
    24
    Images of the install. Neat job. Pump mounted under the container and out of sight.Methanol Injection : Alcohol Injection : Water Injection : DevilsOwn
    https://www.facebook.com/DevilsownMe...ocation=stream
  1. FMIC installing this weekend
    By Turboman-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2011, 18:46
  2. What you up to this weekend?
    By dickys3 in forum General Chat
    Last Post: 11th November 2005, 17:29
  3. Glad I didn't go to Glasto this weekend
    By bravepilot in forum General Chat
    Last Post: 25th June 2005, 07:07
  4. Santa Pod-USC- This Weekend - 8th'9th'10th
    By RAPS3 in forum Major UK Events
    Last Post: 7th August 2003, 20:40
