Sky InsuranceVolks Autos
    Oct 2013
    Heater Problem?....is it a problem?
    Hey all,
    I've recently bought a 2006 A4 S-Line 2ltr TDI. Lovely car but have found what might be a slight issue with the heater / aircon. Hopefully someone will be able to tell me if it's normal!
    I have the ECON on and the AUTO off. I have the air blowers set to 2 bars. This is fine, however, when I knock the air blower speed up to 3 bars, the AUTO lights (on both sides) come on! This only seems to happen when the air blower speed is on 3 bars. If I knock it up to 4 bars and above, the AUTO lights stay off, as I believe they should. Is this normal, it's driving me nuts!
    Cheers,
    NS
    Apr 2012
    NTH Lincolnshire
    55
    I can't imagine this being much of an issue.
    I have mine on auto all the time. The econ button doesn't save you anything and if the heater still works ok just ignore it.
    Brad
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Never noticed on mine. Will check tomorrow. Personally I always leave on auto and just adjust the temp. Also set mine so drivers side sets passenger as well. Stops the wife playing with the buttons
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Oct 2013
    Quote Originally Posted by rizzini7 View Post
    Thanks, that would be great!!
    -NS
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    its normal
    Oct 2013
    its normal
    Thanks. It seems like a strange "feature" tho!
  1. Haldex problem is now abs problem
    By nokia_aid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2012, 13:11
  2. Big Problems, Help Needed, Auto problems
    By GlennMr2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th September 2010, 14:48
  3. HEATER PROBLEMS
    By imported_AudiAuto in forum General Technical / How To
    Last Post: 11th August 2004, 10:56
  4. Audi A4 Heater problem
    By imported_Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th April 2004, 08:08
  5. Heater problems
    By humlicek in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th October 2003, 13:33
