Chris NottVolks Autos
    Oct 2013
    11
    Broken EGR cooler -2006 A4 TDi - Replace cooler or remove and re-map?
    After some advice following broken pipe off EGR cooler. Given the price of a replacement cooler, i would rather spend the money on a re-map and EGR delete.
    Is it possible to remove the EGR and EGR cooler from a 2006 A4 TDI (140) BLB Engine completely and map it out? Anyone experience of doing this or able to explain the finer details of what is required?? Need to take action on this asap as the car is a daily driver and currently has a temporary blank over the exhaust manifold and the engine management light is on as a result.
    Any help much appreciated.
    Regards, Liam
    Dec 2013
    hi did you do it as I want to do this
    Oct 2013
    11
    Harley Monster... no i didnt do the delete and remap in the end, opted for replacement cooler to keep it standard and get it back working again before any tuning. The advice i got from various independant Audi places was that it wasnt as straight forward as i had hoped to remove and remap.
  1. Replies: 7
    Last Post: 12th July 2011, 11:47
  2. 2006 A3 TDI sportback BKD 140 engine oil filter?
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th March 2011, 11:31
  3. 2006 3l TDI A4 avant, noisy engine = injectors?
    By JD09 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th September 2010, 15:07
  4. A3 2006 1900cc Tdi
    By ruby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th October 2009, 21:18
  5. Will vag-com on audi tt 2001 work on my 2006 A3 TDI
    By DIABLO636 in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd April 2007, 23:18
