Chris NottJMB Retrofits
    Apr 2013
    140
    Potential Problem?
    For quite sometime now, I've noticed my temp dial on my dashboard only ever reaches about 70.. I've not experienced any issues yet and it's been like this for quite sometime now...
    I'm doing the timing belt soon so will have the car it bits, so if there is a problem I can tie it in with all that..
    Cheers, James
    May 2012
    RETFORD, NOTTS
    1,753
    check actual temp with vcds to make sure the engine is running the right temp, could be the temp switch, needles, or thermostat stuck open.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Potential problem??
    By Tuddie in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 22nd June 2013, 21:00
  2. 2nd Post, and its a potential problem
    By adi3390 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2012, 23:54
  3. Help needed - a potential problem with a dealer.
    By Sparkie in forum General Chat
    Last Post: 11th February 2011, 20:15
  4. A3 2.0 TDI owners POTENTIAL PROBLEM
    By stevehsv868 in forum Diesel forum
    Last Post: 11th July 2007, 13:16
  5. Potential problem???
    By mikeclark007 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2007, 16:45
