Volks AutosAH Fabrications
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    199
    Is this the temp sensor?
    Going to try change it but is this the sesnor:
    May 2012
    93
    which model and which engine?
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    199
    Awx I think it is. A4 avant 130 tdi.
    It was the sensor. But ive changed it over for a new item from tps and its not giving me and read out on the display
    Chrismawa's Avatar
    Sep 2011
    Tyne and Wear
    199
    Ah it is working but only going to 70 Guess I need a new thermostat!
  1. where is the temp sensor located!!!
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2012, 23:54
  2. Is this the correct temp sensor?
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 20:12
  3. Where about is the Temp Sensor on the A4 1.8 sport
    By threadders in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th December 2007, 13:05
  4. wheres the coolant temp sensor 1.8T v-reg 1999 A3
    By cawood in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2007, 16:37
  5. Help! Where's the Coolant Temp sensor?
    By FactionOne in forum General Chat
    Last Post: 12th April 2006, 09:44
