Afternoon...
Well NHN popped by this morning and fitted the cruise control to my A4.. during the scan up popped glow plug errors for all 6 plugs..
The car is working fine.. I have had no issues starting it.. nor any lose of power whilst driving. As nigel mentioned having 6 faulty all at once seems unlikely.
But I post below the snippet from the VCDS scan.. anyone have any ideas - could it be the wiring loom ? Any idea on the sort of price it maybe to get this fixed...
The car has done just over 70000m - (2005 model) - but I do not know of any of the glow plugs have been replaced in the past.
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 401 F HW: 8E0 907 401 AJ
Component: 3.0L V6TDI G001AG 0050
Revision: --H01--- Serial number:
Coding: 0011171
Shop #: WSC 06325 000 00000
VCID: 224D899DFD24650EA27-8077
6 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
Readiness: 0 0 0 0 0
cheers
Matt
Coding: 0011171
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 840 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Duty Cycle: 24.5 %
Temperature: 23.4°C
cheers
Matt
