    Oct 2013
    Stoke on Trent and North Wales
    73
    Follow Archies On Twitter
    VCDS errors help
    Ive done a scan of my A4 and i have got a couple of errors i hope you can help me with, im hoping i can repair them my self when i find out how to, heres the errors.
    First Error:
    2 Faults Found:
    000833 - Camshaft Position Sensor (G40)
    P0341 - 000 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 3
    Fault Frequency: 5
    Reset counter: 255
    Mileage: 120351 km
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    RPM: 84 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 9.20 V
    Bin. Bits: 00101000
    Idle Stabilization: 0.0°KW
    (no units): 3.0
    012296 - Camshaft Position Sensor (G40)
    P3008 - 000 - Signal Out of Range - Intermittent
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 120351 km
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    RPM: 252 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 9.50 V
    Bin. Bits: 00101000
    (no units): 35.0
    Second Error:
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BM
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6DD1395D27FA78764F5-515C
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    41-10 - Blocked or No Voltage - Intermittent
    Hope some one can shed some light on these for me with a possible fix.
    Archie
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,470
    They're all intermittent , so the first step is to clear them and see if they come back.
    If the two G40 ones come back then check the wiring to the sensor is secure, if it is then suspect the sensor.
    If the V113 one comes back then check the wiring to the motor on the side of the heater matrix that this refers to, I've had problems with the contact pins corroding so worth cleaning them, failing that take the motor off and check if the linkage moves freely, if it does then it's probably the motor.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    26,720
    As above, but also if the HVAC comes back, do a basic setting 001 to allow calibration & check on all heater systems, which may clear it.
    Oct 2013
    73
    Thanks for the replies, I will check the wiring Dave and see if everythings ok there.
    NHN, i have only used my VCDS the once so im not sure how to use it yet so your answer is confusing to me. I will have to carry on reading about it and trying to fathom out everything i can do with it .
    Archie
  1. VCDS - Boost help please.
    By JS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2011, 11:51
  2. Swindon Area VCDS Scan HELP!!
    By N7 JNS in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd June 2011, 11:09
  3. new vcds owner help please
    By Duktor in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2010, 10:39
  4. Brake Pedal Monitoring Error HELP HELP
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2010, 23:11
  5. Replies: 24
    Last Post: 10th October 2010, 17:40
