Chris NottSky Insurance
    Jul 2012
    Enfield
    21
    rear washer leak
    Hi hope some one can help, have had a leak on my rear washer and think i have found where it is, between rear hear lining and as it goes along the rear boot hing.
    I need help with undoing the rubber grommet and gaining accesess between the removed head lining strip and the hing.
    Hope i have explained this well anough.
    27,087
    Man if its anything like the 8P, its a pita to remove/refit tbh, ideally heating the rubber would help, but has wires inside so care to be taken.
  1. Rear Washer leak
    By ctd in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th November 2012, 20:31
  2. Rear washer leaking into boot on offside.
    By garethk-d in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2012, 10:53
  3. rear wiper washer leak causing bose amp problem on avant
    By alfie155 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 00:47
  4. Rear washer leaking, front near side...
    By SixDegrees in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2009, 00:09
  5. Rear washer leaking at front of car
    By Syzygy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2006, 09:54
