AH FabricationsJMB Retrofits
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By mattjarv
Thread: 2.0 TDI Mystery... can you solve?
    Jan 2012
    65
    Hi guys,
    Wondering if you can help me with a problem which nobody else has been able to so far. I have an a4 Cab 2.0 TDI and between 2000-3000rpm on a slow accelerate, the engine jerks a little and starts making a hissing/sucking sound. If I floor it, this doesn't happen but only does on slow-med accelaration.
    I've taken this to Audi and several other garages and they have run a scan and nothing. Someone said it was the fly-wheel, but it wasn't, others the EGR Valve, it wasn't and the problem continues!
    SO this is just a post to see if anyone has had this before with the same symptoms and could possible shed light on to the problem?
    Thanks!
    74
    i had a similar issue where it whistles had the egr cooler pipe replaced and fixed it.. didnt happen at full speed just on slow acceleration or revving the engine stood still it would happen occasionally
    Jul 2012
    56
    Mine does the same thing I'm thinking it's either throttle body is sticking, turbo vanes sticking or injector wiring harness.
    North East
    607
    Quote Originally Posted by mattjarv View Post
    Hi guys,
    Thanks!
    My money would be on an EGR related issue....................
    Aug 2008
    Leeds
    152
    Had something very similar to this on an old 02 plate Golf GT TDi PD 150.
    The car would jerk on acceleration, usually around the point where the turbo would kick in and you could hear a loud(ish) sucking/hissing sound in the cabin that was much louder outside.
    Turned out to be a kn4ckered intercooler pipe.
    J
    2003 A4 B6 1.9 TDi 130 Quattro Sport
    2007 A4 B7 2.0 TDi S-Line Cabriolet
    Jul 2012
    Enfield
    21
    Have you checked the vacume actuator that does the flaps (long to short air intake) which i believe opperate 1800 rpm.
    Just a thought.
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Two big suspects at this stage.
    First is the EGR, which is active at this speed, and for which a dirty EGR causes hesitation at this rev range.
    Note that dirt in the EGR is one thing, but that the pipes around the EGR can also get dirty, and are not so easily checked.
    Follow-on from the EGR is that there is (apparently) a cooler for the EGR flow, and there is a habit of these cracking. (See B7 2.0 TDi EGR cooler pipe blown off)
    Second option, which would make less hissing, is that the turbo VVT actuator is leaking. The VVT is actuated by a tennis-ball sized vacuum actuator on top of the turbo, which has a modulated vacuum "flow" from a control trembler valve on the rear bulkhead of the engine bay. If the hose between the trembler valve and the VVT actuator has come off or damaged, then it would hiss (but probably not very loud), but the VVT (and hence the turbo) would not work properly. Check this assembly with a cold, non-running engine, and grip/squeeze the actuator to pull its shaft, which should move easily but make no hissing noise.
    A4 B7 Cabrio 2007 2.0 TDi Black "Sport"
    Jan 2012
    65
    Thanks guys all sounds rather expenseive but lots to check!
    Mar 2011
    North Wales
    206
    Quote Originally Posted by Alexthesparky View Post
    Just a thought.
    That fixed mine hesitating and part is only about £10
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Quote Originally Posted by Tolak View Post
    Adding a third; since the diesel system does not have vacuum in the manifold at any stage, it requires a vacuum pump, which tends to have a reservoir. Cracks in the hoses or the reservoir will hiss, but will also decrease the servo "muscle" and hence degrade the operation of the turbo, and hence the performance.
    I'm investigating this on the daily hack; at the start of the journey, the turbo is less effective, but become more effective once the engine has run for a while. Might be the new turbo being tight (but 2k miles done now), but worth checking as the vacuum system had to be disturbed to fit the new turbo. I will report back once proper tests are done.
    Jan 2012
    65
    Hey Tolak,
    My car seems to make this nice and do the jerking more when the engine is heated up. Does it in most gears and even 70 on the motorway in 6th gear (where the rpm is between 2 - 3000rpm is was doing it but always more when the engine is hot.
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Hey Tolak,
    Working with old-skool logic (rather than actual knowledge), but it seems that if the engine is jerking it is a control that is changing a state quickly.
    So the EGR is unlikely to do this (and would not be relevant on the motorway).
    It might be a sensor that has a backup (some Lambda systems have two, and can run with one) so you have one miss-reading, and this drops in and out of being acceptable.
    Similarly, the flap (mentioned above) might have a marginal actuator, so it sucks from one position to the other, and the transition causes a pulse.
    What it might remove from consideration is the broken component mechanism; if something is broken, it will not cause a changing system.
    With the modern systems, if a sensor goes bad, a CEL will be set, and so you will have a fault that can be followed. If not CEL is set, then you may have an actuator that is not working correctly, or a secondary actuator that is broken/intermittent. (eg turbo is actuated by vacuum, which the ECU cannot see, compared with the electrical modulating valve, which it can "see" and run Built in test (BIT) to report a fault.
    Generically, and excuse me for stating what may already be obvious to you, you are either misleading the controller (eg leaky system giving different environment to that which the controller perceives) or interfering with the controls (eg stopping the controller from achieving what it thinks it is doing). And to stop the CEL being lit, these errors are beyond the electrical interface for the controller.
    But another less obvious input is the communication from one sub-system to another; if the gearbox controller reports something, it may cause the engine controller to change its "attitude". But this would also have to be a non-fault condition, and somehow intermittent, so is most unlikely.
    Jan 2012
    65
    I'm taking the car into Audi tomorrow who have agreed that if what they think it is, isn't, they wont charge me for it and will keep looking unti they find out what it is! I was worried they would change something and then charge me anyway! Will let you know the outcome!
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Unlikely but I did get juddering as if the car was going to stall at med-high revs and it was the fuel filter.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Jan 2012
    65
    In the end it was the ECU that didn't marry up with the remapping I had done at Top Gear in St Albans. They said they did a bad job and I got it re-done (somewhere else) and now it's perfect. Think it messed with the boost pipe as well.
    Tolak likes this.
  1. starting?TDI 130. MPG? CAN YOU HELP?
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2012, 19:56
  2. Can you help? A3 2.0 TDI
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd February 2010, 18:23
  3. Audi A3 TDI Owners: Can you help me out a sec?
    By sibby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2008, 15:54
  4. A4 TDI S,SE? WHICH ONE CAN YOU HELP
    Last Post: 13th December 2006, 10:12
  5. Replies: 4
    Last Post: 21st November 2006, 20:22
