EM TuningBadger5
    Jun 2004
    53
    A4 Avant - Nozzle Jet Adjustment - Any tips?
    Hi all
    The nozzle on my 06 A4 avant was blocked, so I duly pulled off the nozzle and cleaned it.
    It now squirts but no matter which way I point it, it seems to hit the inside of that plastic cover.
    The nozzle I have is the single jet (like this picture I found) http://img849.imageshack.us/img849/9536/gedc0992z.jpg but with the two hole washer jet cover.
    Also when the wiper is moving (with the little black cover off), the nozzle doesnt move with the wiper arm. Is this correct? So if pointing up, it stays pointing up all the time.
    Any tips for putting it in the right place?
    ruairi83's Avatar
    Dec 2007
    739
    Use a pin and move test move test until happy that's what I did.
    Aug 2011
    196
    I could well be wrong, but I dont think thats the correct jet - certainly the one on my B6 is twin jets and a different design. And it moves with the spindle.
    As per this one http://thumbs4.ebaystatic.com/d/l225...vqP8Rb8Q2w.jpg
    Mike.
    seandom's Avatar
    Dec 2012
    Hampshire
    132
    I have a 56 plate Avant and my jet is the same as Mike-B's
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    726
    Quote Originally Posted by seandom View Post
    Same here
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Aug 2011
    196
    If it helps, I had to replace the rear wiper arm today - the jet locates in a u shaped bracket which is what stops it turning.
    Then the cover (with the two holes aligned to the jets) goes over the top. Hope this helps - Mike.
  1. Thinking about an A4 Avant any tips?
    By Gwilspeed in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th May 2012, 18:09
  2. Any tips for installing a headlight adjustment motor?
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th March 2010, 22:17
  3. Load Mats and Washer Jets adjustment?
    By evotista in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2004, 19:58
  4. Any tips /advice on a A6 greatly appreciated
    By cruzanS in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th November 2004, 17:12
  5. JUST GOT A 00 S4. ANY TIP ON TURBO UPGRADING???
    By imported_AmbestenS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2004, 03:24
