Volks AutosJMB Retrofits
Results 1 to 15 of 15
    yorkster001's Avatar
    Aug 2010
    York
    84
    New engine mounts?
    Just coming up 100k and the engine mounts are starting to show their age. Vibration, added noise and clunky shift all pointing to one or both gone. Just been to the local stealer and they want £225 for the pair off the shelf. I've seen other non OEM mounts advertised and wondered if anyone had any experience of non OEM items? I'm not after solid nylon mounts as I prefer the smooth ride on OEM mounts, just want to save some pennies if poss. Any suggestions? Failing that, anyone know anywhere online cheaper than £225 for OEM items? Cheers
    A4 (07) 2.0T FSI S Line - Dolphin Grey
    Mods: Remap, DIS, Washer Bottle sensor, AUX Input, Ambient Light, Puddle/Warning Lights, Aftermarket SATNAV/DVD, VAG-COM Tweaks.
    Future Mods:
    B5 Caps, H&R Springs, 19's
    2,185
    You could try eurocarparts they sell lemforder parts which are the same as the Audi mounts but they just have the Audi part number & logo ground off. They also have a 50% off on there web site at the moment (but not sure if the mount are on the sale)
    Mar 2013
    Berkshire
    399
    Well I can maybe offer some advice here.
    The mounts you were quoted were mostly likely the common a4 b7 mounts part numbers :
    8E0199382AJ
    8E0199379BG
    Which will be around £225, trade price for them is about £180. So not much of a mark up.
    Euro car parts might stock them but they are not listed on there websites well for me atleast. The lemforder as stated above are generally the audi part with grinded off numbers and labels as I have seen this first hand with the suspension arms etc.
    Now in my case im planning on keeping my car for longer period of time so im going for the RS4 engine mounts which is a direct fit.
    They will last longer than OE mounts and will make it slightly stiffer. As you would imagine the RS4 engine is a lot heavier than the 2.0t lump. If this is something you are interested in the part number is as follows:
    08D0199379AD - £92 trade, £114 retail
    So if you did decide to go for purchasing from the stealer. I would highly suggest to get the RS4 mounts. The above part number works for both sides of the vehicle.
    Otherwise to keep the ride the way it is try stay clear of solid mounts as they are not as pleasant and change the ride to which you will be used to.
    Hope this helps
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,356
    Get B5 S4 mounts, eBay quotes less than a quarter of the price you guys are paying.
    g00se's Avatar
    Nov 2010
    Reading
    265
    sounds like a good opp for an upgrade to me!
    i cant say enough good things about 034 kit.. Motor Mount, Density Line, B5, B6, B7, and C5 - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
    well worth getting a $20 poly snub at the same time - mine really made shifting feel more direct
    i got my stuff from Eddie @ WOT Motorsport great guy and quick delivery
    goose
    Current:
    '08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Past:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    2,185
    Quote Originally Posted by Giosabcsl View Post
    Just to be clear you are talking about the B5 RS4 mounts (which is the v6 lump), also there is no 0 at the start of the part number.
    The problem with "ebay" mounts if you never know the quality of the parts you are buying, you can by a full set of control arms for less than £100 but they don't last 6 months!
    Mar 2013
    Berkshire
    399
    Quote Originally Posted by B5NUT View Post
    Yes you are correct there is no "0" at the beginning of the part number. And yes the b5 Rs4 mounts.
    my bad
    2,185
    One other thing to note is one of the engine mounts on the B7 has a sensor, which the B5 RS4 mounts don't have so fitting them will put a fault code on the engine ECU, what problems that will cause with the ecu other than just a fault code, I have no idea.
    Also changing the engine mounts at 100K is a little early, mine really started to show there age at 250K, have you checked out the gearbox mounts, as they are not as substantial at the engine mounts, and will wear out quicker, after all the gearbox is well connected to the engine and are under just as much load. My gearbox mounts after 250K were completely shot and I was surprised they passed the MOT.
    Mar 2013
    Berkshire
    399
    My mounts have done almost 90k miles. The drivers side mount is shot and has the purple stuff running out of it already. As for the passenger side one still seems on the healthy side but of course its best to change in pairs.
    As for the sensors some b7 have sensors especially the S4 and RS4 but I dont know of a normal b7 having a sensor my 2.0tfsi does not have.
    2,185
    The TDi engine cars have the sensors, but may be the 1.8 & 2.0 petrol don't have them. The OP does not states what engine he has so figured I add that information. If your front engine mount is shot then I would check the gearbox mounts over, one of my mounts had badly cracked and the other side, rubber inner had come away from the metal mount. With the state they were in you could see the gear stick move when you put your foot down and backed off, it was like a nodding dog....
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,356
    Didn't know they had sensors does the b6 have sensors?
    2,185
    Yes, I replaced one on a B6 1.9TDi which showed an engine mount error on the ECU.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,356
    Sorry to revive an old thread (just 6 days old although allot happens in 6 days) just wondering if the RS4 mounts part number 8D0199379AD was for one side or both, someone on Audizine also spoke about 8D0199382AR and from what I can make out one of the two part numbers is the kit including left and right mounts, snub mounts and mounting hardware, just wanted to know which one was the full kit.
    Mar 2013
    Berkshire
    399
    Quote Originally Posted by DieselJake View Post
    Hey Jake,
    The part number 8D0199379AD can be used for left or right side its a "universal" mount.
    As for the kit I cant comment on. But the above part will work on any B7 shape that the mounts dont require sensors as some B7's have engine mount sensors. Thou in my case the A4 B7 2.0tfsi doesnt.
    hope that helps
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,356
    Cheers that's perfect, ordering two of those today
  1. New Uprated Engine Mounts
    By AndyC in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2011, 12:25
  2. Engine Vibration - Would a new snub mount help?
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2010, 17:15
  3. possibly need new engine mounts.
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2007, 15:42
  4. help buying new engine mounts.
    Last Post: 25th October 2006, 08:57
