EM TuningAH Fabrications
Thread: alarm woes
    Jan 2011
    9
    alarm woes
    evenin all,has anyone had issues with the headunit coming on when they unlock the car and then you can only turn it off by switching the ignition on and off????? cheers
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    no
    scan for fault codes
    27,075
    In an ideal world, testing in another A4 would be useful, however check door rubbers for broken wires incase of a short, remove radio & disconnect for 5 minutes, ignition switch is a remote one aswell as obscure as that sounds, but something is telling it to turn on & ignition does this with a kline/bus signal.
  1. Alarm woes - Keeps going off
    By Das Chin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2011, 10:21
  2. Alarm Woes
    By chrissy1502002 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2010, 13:12
  3. Alarm Woes - Drivers door closed - DIS says Open
    By A3steve in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2010, 12:36
  4. Avant Alarm woes.
    By orb in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th February 2010, 23:46
  5. A3 Alarm
    By markp in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2003, 15:11
