AH FabricationsBadger5
Results 1 to 15 of 15
    Jun 2010
    63
    Camshaft related error codes
    Hi guys, hoping you may be able to shed some light. On my A4 3.2 Cab I've had the following two codes come up:
    2 Faults Found:
    000033 - Bank 2: Camshaft A (Intake)
    P0021 - 008 - Retard Setpoint not Reached (Over-Advanced)
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Mileage: 114783 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2432 /min
    Mass Air / Rev.: 545.0 mg/str
    Temperature: 91.5°C
    Part Throttle
    Bin. Bits: 00000000
    Steering Angle: 127.66°
    000838 - Camshaft Position Sensor (G163)
    P0346 - 006 - Implausible Signal
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 114815 km
    Time Indication: 0
    Freeze Frame:
    RPM: 800 /min
    Mass Air / Rev.: 114.5 mg/str
    Temperature: 49.5°C
    Idle
    Bin. Bits: 00010000
    Speed: 0.0 km/h
    Readiness: 0010 0001
    I've taken it to a garage who have said that their tools aren't good enough to take this further as it could be a timing issue. And that it needs a specialist.
    The car does seem lumpy/shaky on idle. But general running seems fine.
    Are there any other checkls I can do with VAG-COM before I have to concede and take it to Audi?
    Steve
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    720
    Having similar issues mate, if you find my thread and see if your faults are similar. Sorry can't link it on my iPad. Currently my issues are being put down to worn DMF and clutch and hopefully clear up once replaced. You getting misfire readings??
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Jun 2010
    63
    Hey man, thanks for the response.
    I'm fairly new to VAg-Com so i havn't done anything more than reading the error codes.
    rizzini7's Avatar
    Jun 2011
    720
    Suppose you're gonna say yours is auto?? In which case haven't a clue. Mines in for repair now so will update when I get it back
    Jun 2010
    63
    No it's a manual petrol.
    rizzini7's Avatar
    Jun 2011
    720
    Hoping mines fixed once clutch and flywheel are replaced. Otherwise I haven't got a clue. Helpful I know will keep informed.
    rizzini7's Avatar
    Jun 2011
    720
    Garage rang, picking it up tomorrow. Will see how it goes! Bumped my old thread for you. Ignore some of the code they're unrelated
    rizzini7's Avatar
    Jun 2011
    720
    My issues are still present after having new DMF and clutch. Heres the scan:
    Address 01: Engine Labels: 06E-910-559-BKH.lbl
    Control Module Part Number: 8E0 910 559 Q HW: 8E0 907 559
    Component and/or Version: 3.2l V6 FSI 0020
    Software Coding: 010C0003180F0118
    Work Shop Code: WSC 66565 257 00032
    VCID: 3B7378807A6DC4C6811-806E
    4 Faults Found:
    000013 - Camshaft Positioner (Bank 2 Exhaust)
    P000D - 008 - Slow Response - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 154759 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2144 /min
    Mass Air / Rev.: 332.5 mg/str
    Temperature: 82.5°C
    Part Throttle
    Bin. Bits: 00000000
    Steering Angle: -84.00°
    000913 - Camshaft Position Sensor (G301)
    P0391 - 006 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 5
    Reset counter: 35
    Mileage: 154813 km
    Time Indication: 0
    Freeze Frame:
    RPM: 736 /min
    Mass Air / Rev.: 136.3 mg/str
    Temperature: 84.0°C
    Idle
    Bin. Bits: 00010000
    Speed: 0.0 km/h
    012410 - Air Intake System
    P307A - 009 - Flow too Low - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 155183 km
    Time Indication: 0
    Freeze Frame:
    RPM: 736 /min
    Mass Air / Rev.: 81.8 mg/str
    Temperature: 88.5°C
    Idle
    Voltage: 14.28 V
    Speed: 0.0 km/h
    000104 - MAP/MAF <-> Throttle Position Correlation
    P0068 - 007 - - Intermittent
    Freeze Frame:
    Fault Status: 00000010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 155183 km
    Time Indication: 0
    Freeze Frame:
    RPM: 704 /min
    Temperature: 88.5°C
    Idle
    Voltage: 14.18 V
    Bin. Bits: 00000010
    Readiness: 0000 0000
    Thinking of changing the camshaft sensors next. Any luck with yours????
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    Don't the chains have a habit of stretching on these? I cannot recall the block number but you can see the correction value in there somewhere
    Apr 2013
    Aberdeenshire
    590
    Quote Originally Posted by Byzan BAHons View Post
    Try measuring blocks 208 and 209 it does sound like a chain issue to me.
    rizzini7's Avatar
    Jun 2011
    720
    Do you need to check with it running warm or from cold? (Or both??)
    Apr 2013
    Aberdeenshire
    590
    Quote Originally Posted by rizzini7 View Post
    Either or vcds should tell you if it's within range.
    rizzini7's Avatar
    Jun 2011
    720
    Also when it says fault priority is 1= serious or 5= serious? Cheers
    Jun 2010
    63
    I took mine to a local specialist. They advised that there are 4 camshaft sensors on my car.
    They swapped a couple of them around to see if the error came back but followed the moved sensor to tell if it was the sensor or timing. It's been a week and the light hasn't come back on. Am going to read for codes again anyway. But it could just have been a dodgy connection that they have fixed by moving it.
    rizzini7's Avatar
    Jun 2011
    720
    Cheers for the update mate. Hoping mines just a dodgy sensor or wiring. It seems a Hugh coincidence the issue started after I had a new electric fan fitted where the chap messed up a load of other electrics (aircon temp sensors and levellers on xenons). Going to Tps for quote on the sensors
  1. Error code 00519
    By Jules in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd August 2005, 12:18
  2. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
  3. S4 Error Codes?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2005, 19:47
  4. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
  5. Flashing error code- "1n 1"
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 12:27
