Sky InsuranceAH Fabrications
    Coath's Avatar
    Jun 2013
    22
    Heater only blowing warm
    So , the first cold morning today so i decide to crank up the heater, it is only blowing warm air but gets hotter whilst driving at 60mph, temperature gauge reaches 90 fine.
    I know the thermostat housing is leaking slightly, i have the new one which will be replaced shortly would this be having any effect ?
    Coolant is g12
    Does anyone have any suggestions where to start ?
    Thanks in advance
    27,094
    Fix the leak 1st and maybe consider changing the thermostat at same time to discount this given you're in that area, if its not too expensive, then see if its improved.
    I always work on basis if there are existing known multiple issues, they need resolving ideally 1st before looking for new issues not known of.
    Coath's Avatar
    Jun 2013
    22
    I read a few articles on various forums for things to check , so this evening I checked both inlet and outlet hoses going into the matrix, both are getting hot , I bled the system didn't seem to have any air in there , I did notice that the bottom hose coming from the coolant bottle is not getting hot ?
    Would a faulty/leaking thermostat housing cause only warm air to the cab and hot air whilst driving at speed ?
    Could it be the motorised flaps, if so how would I check these
    Jul 2007
    770
    I would say leaking stat which is stopping it warming up quickly.The flaps would prevent it giving heat at all speeds.Easy enough to remove the glove box and see if they are working OK.The temp gauge is not precise.Dodgy stats have been a bane of my decades of motoring.They don't seem to be any more efficient or reliable than 50yrs ago
    Coath's Avatar
    Jun 2013
    22
    One thing I forgot to mention is that last night whilst trying to bleed the system I had the coolant cap off to try and get rid of any trapped air, So I ran the car up and all was fine for a little while, but then the coolant level started to rise to the point it was over flowing from the header tank , Would a faulty thermostat cause this ?
    I am going to replace the thermostat housing tomorrow , I hope this cures the problem
    Jul 2007
    770
    The system relies on the cap sealing tight to allow the pressure to keep the temp down.Same as you musnt remove the cap when hot cos it will throw hot coolant at you
  1. A6 1.8t air con blowing warm when stationary, cold when moving
    By morepower in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th August 2013, 17:20
  2. Red brake warning light but only when warm
    By Thacker in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th May 2013, 19:35
  3. heaters not blowing much!!
    By dancupra225 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2013, 15:19
  4. AC ont working blowing warm air
    By pink.teg in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th July 2012, 10:49
  5. How long does your heater take to warm up?
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 13:45
