Chris NottMonster Motorsport
Results 1 to 7 of 7
Thread: Idle misfire
    Jan 2012
    56
    Idle misfire
    For a while my 2.0tfsi q avant has been running a little lumpy on idle, once you get your foot down and moving its good, and once it warms up it'll idle ok.
    Then it's started getting a little worse, wasn't throwing any codes but the other day while running I got the engine light and it registered a misfire on 4 as well as a misfire on all cylinders.
    Recommendation was to change the coils and plugs, which I've done and it's made no difference.
    If anyone's got any ideas what to look at next I'd be very interested to hear.
    Big Al's Avatar
    4wd + turbo = fun!
    May 2011
    West Midlands
    222
    Check the condition of your MAF, if dirty replace. Try replacing the impulse sensor? Situated just down & back from oil cooler & oil filter on rhs of bay. That helped mine. Also I recommend changing the PRV valve (if old) and gasket on rocker cover. See my build thread for details, part numbers & costs.
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Jan 2012
    56
    Thanks for the pointers, I'll get in there and check things out. The MAF is operating according to obdii diags but no idea what state it's in.
    Jan 2012
    56
    Ok, been a while but have been through and had all the sensors checked, compression checked, had the induction chemically cleaned, all no improvement.
    However...
    The cars been sitting idle a lot of the time recently, to the point the battery has run flat twice.
    First time I jump started the car and for a whole it was aweful, sounded like a tractor, obviously running on less than 4 cylinders. Once it ran for a while and warmed up, after switching off and starting it up again, it got better, back to the 'normal' misfire.
    Next time it ran flat I put the car in charge and started it up the next day from cold. It ran like it would generally do from warm, still hear the misfire but pretty good really.
    So now I'm thinking alternator, ignition loom?
    Any thoughts?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,911
    clean TB ?
    Oct 2013
    268
    Whats the alternator putting out?
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    653
    Hi mate, had similar issue on mine. Don't quote me on this as mines a v6 and chain drive. So may not apply to yours
    But turned out to be a duff cam adjustment valve on mine. Car would run rough occasionally and register misfires. Mine was doing it mainly from cold start after 5 minutes or so.
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
  1. HELP PLZ 2.4 v6 irratic idle / misfire
    By cammy43 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th November 2011, 20:30
  2. Replies: 41
    Last Post: 28th September 2010, 14:18
  3. S3(8P2): Misfire cylinder 3, no engine code faults - idles like a pig
    By warren_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2010, 11:08
  4. Lumpy idle/small misfire on stage 2+ S3, please help?
    By jamieswales in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th May 2010, 08:23
  5. More problems argghh!! misfiring on idle....
    By will.f_1.8t in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2009, 16:01
