Monster MotorsportChris Nott
Results 1 to 7 of 7
Thread: Air system fan
    Feb 2013
    Wiltshire
    345
    Air system fan
    Hi all,
    does anyone have any details on how the heater fan in the passanger footwell can be removed? I want to take it all apart to give it an overhall and clean.
    Cheers!
    27,026
    What's wrong with it, as if its the main fan unit that plums into the main air housing unit, messing with these can affect the balancing & make a horrible noise when reinstalled & running, which is why its better to fit a replacement if its got an issue.
    Feb 2013
    Wiltshire
    345
    Its pretty dirty and has a mildew-like smell. I can see that a few fins have weights on them for balancing, so wasnt planning in touching them. Wanted to get the unit out, clean the fins and the housing as well as checking the carbon brushes to see if they need replacing. Also probably give the motor a clean.
    27,026
    TBH by the time you've done that, you could of had a new unit fitted done & dusted mate, but hey I'm all for stripping parts down etc
    I actually did this to my own unit, but it was fubar, so swapped it out for new.
    Feb 2013
    Wiltshire
    345
    probably will go down replaceing it at some point, but its a good learning point. Whats the best way to access it to get it out?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    if its not broke an all that
    Feb 2013
    Wiltshire
    345
    True, but I really want to clean out the system to get any mildew and crap out. Changed the filter again today and that will make a difference, but want it nice and ready for the winter.
  1. 8l s3 air con fan not working help
    By Duktor in forum Air Conditioning
    Last Post: 23rd November 2010, 19:35
  2. Air con fan under bonnet no longer spins
    By Monsoon in forum Air Conditioning
    Last Post: 27th March 2010, 14:11
  3. Air con Fan prob
    By S3 Marky P in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2009, 23:35
  4. Air Con fan killing battery.
    By otis_b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th January 2008, 22:14
  5. Secondary Air System Fault
    By robby in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd July 2005, 19:30
