Chris NottSky Insurance
    Apr 2013
    140
    Halfords 501LED sidelight issues
    This weekend I managed to get round to converting to BI-xenon and thought I'd get some nice white LED, assuming they'd just work..
    Obviously, they don't, the flicker and I get a bulb out warning because they done pull enough current.
    Is there a way in vagcom I can tell the car to lower its tolerances so to speak to allow me to use the bulbs..
    OR
    Can I put a resistor in parallel (or would it be in series) to trick the car into thinking it halogen? I have **** loads of resistors so.
    I'd prefer the vagcom method and it seems pretty pointless putting efficient LED's in the car to then add unnecessary resistance to increase the load on that line..
    Anyone?
    Cheers, James
    Jun 2011
    Wellingborough
    1,126
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Apr 2013
    140
    I get the concept, but it seems a bit iffy having a loose bulb, powered, and just floating around in the headlight housing...
    Cheers, James
  1. Sidelight issue
    By rizzini7 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th July 2013, 07:28
  2. Trups Sidelights - Heat issues?
    By ESD1711 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th May 2013, 23:23
  3. Newbie: Has S3 performance Issue
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 23:07
  4. Bumper Issue
    By tonyrmay in forum The Welcome Section
    Last Post: 23rd July 2003, 13:32
  5. Sidelights for A3 (97R)
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2003, 16:38
