Chris NottEM Tuning
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By Def-87
Thread: Drl question
    Apr 2013
    Gloucestershire
    136
    Drl question
    Just bought these drl strips for my headlights now I no how to install them but I dont have a clue on how to wire them up. Ive tried searching the web but cant seem to find anything on how to wire up. Im not the best at electrics so all the advice would help. Thanks in advance.
    Ash
    Jun 2011
    Wellingborough
    1,127
    Ash.
    Do you want them just to come on as a DRL when you turn the ignition on? would you want them to turn off when you turn the lights on or do you want them on all the time?
    Trups
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Apr 2013
    Gloucestershire
    136
    Im after fitting them so there on all the time if you could help that would be great help.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,099
    Open the housing and wire them into the sidelight (I think).
    Jun 2011
    Wellingborough
    1,127
    All you need to do then is make up a loom, buy a couple of meters of wire, red and black, connect them to the DRL's each side and then earth the black one.
    For an ignition wire you can get one off your headlight switch, if going to that I would also put an inline 10amp fuse just incase the DRL goes, you only want the fuse to go and not anything else.
    Trups
    EM Tuning Lighting.
    Apr 2013
    Gloucestershire
    136
    Sorry if this is obvious bit im rubbish with electrics when earthing does this have to be the negative just wondering because iv tested the drl and the red is negative for some reason would i attatch this to the body of the car also how would i tell which is the ignition cable. thanks for the help
    Jun 2011
    Wellingborough
    1,127
    If they wire are the wrong way around then just remember which is which.
    Have you got any tools to do a test to see, when you pull the switch out just test all, I don't have a B7 so wouldn't be able to tell you.
    Trups
    EM Tuning Lighting.
    Def-87's Avatar
    B7 2.0 TFSI Quattro
    May 2013
    Suffolk
    45
    My DRL's are wired through my heated washer jets which means the DRL's are on all the time that ignition is on. This is easiest way to wire them as you dont have to go through bulkhead
    t8ups likes this.
    AUDI A4 B7 2.0 TFSI QUATTRO
    HID'S, CUSTOM DRL'S, LED INTERIOR LIGHTING, CRUISE CONTROL, BLUETOOTH
    Apr 2013
    Gloucestershire
    136
    Ill look into that aswel will i still need to put the fuse in also with earthing the negative is that to the frame or is there an earth cable i attatch it to and im unsure if mine has heated washer jets is this a standard thing.
    ash
    Apr 2013
    Gloucestershire
    136
    Iv decided to go with the washer jets but i do not have a clue how i attatch it or what with heres some options i have in the pics any one give some advice on the easiest way of wiring up my drl.20131015_204229.jpg20131015_204241.jpg
    Oct 2013
    East Sussex
    214
    Strip the wire you intend to piggyback off and solder the wires together and then use a bit of heat shrink to protect them.
    That's how i would do it anyway
    Apr 2013
    Gloucestershire
    136
    Woudnt this cause any problems
    Oct 2013
    East Sussex
    214
    What problems?
    Apr 2013
    Gloucestershire
    136
    Thats what im tryin to find out i was going to go down the same route but not soldering just tape up with lekie tape.
    Oct 2013
    East Sussex
    214
    I wouldn't advise it, but it's entirely up to you.
    If you are really not keen on soldering the wires use a terminal block and a piece of heat shrink to protect the connection from any moisture
    Apr 2013
    Gloucestershire
    136
    Ok ill give terminal block a blast tomorow if that fails il give the soldering a gi cheers for the help
    Oct 2013
    East Sussex
    214
    No problem
    Apr 2013
    Gloucestershire
    136
    Finally installed
    Oct 2013
    East Sussex
    214
    Jobs a good'un :D
  1. Quick question about S3 8P LED DRL's
    By ApolloS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2 Weeks Ago, 21:17
  2. another DRL question...
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th May 2010, 16:44
  3. Facelift owners with DRL's, headlight question
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 11:22
  4. DRL Question
    By mac1403 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th October 2008, 21:56
  5. DRL question
    By stewarta13wsb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2007, 21:49
