All you need to do then is make up a loom, buy a couple of meters of wire, red and black, connect them to the DRL's each side and then earth the black one.
For an ignition wire you can get one off your headlight switch, if going to that I would also put an inline 10amp fuse just incase the DRL goes, you only want the fuse to go and not anything else.
Trups
