    Sep 2013
    7
    Drive Shaft Fell Out ?!!!!
    Evening All
    Was doing about 5mph today and the drive shaft fell out of the CVR Joint ?!... What hold the splines on the drift shaft in to the CVR Joint on the wheel side ?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,361
    a circlip fitted into the groove on the shaft holds it in, but they can break up causing this. Problem is when it pulls out of the joint it can scuff the splines up making it impossible to push the shaft back in. I had to get a new/used shaft/joint
    Sep 2013
    7
    Thanks for coming back to me Byzan... the AA guy drove the shaft back in to the CVR in and i drove it home... just a circlip needed then ? Is it available as a separate part fro the CVR ? :D
    Apr 2004
    12,361
    the clip lives on the shaft. If AA man drove it in and you drove home, it's more likely still there and some unluckyness has taken place. I think the clip is part of the shaft from memory
    Sep 2013
    7
    Sorry Byzan, just to confirm......are you saying that its more than likely that when the AA man drove it back in, the clip might have re engaged or that the clip is somewhere in the boot / grease ?
    thanks again
    Apr 2004
    12,361
    I'd have expected it to pop back out if the clip wasn't there to re engage. It may have broken a section of it I guess which could in theory worst case be in the grease. If you are worried, have the joint removed and grease cleaned out. That should show up anything that's broken/missing and cost no more than replacing a cv gaiter for MOT
  1. S4 Prop/Drive Shaft?
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2006, 16:35
  2. Drive Shafts...
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2005, 23:57
  3. whats a drive shaft boot? and how much to replace
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2004, 10:23
  4. vacuum pump / drive shaft
    By ajmackie in forum General Technical / How To
    Last Post: 9th October 2004, 20:44
  5. Vacuum source / drive shaft
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 03:30
