Chris NottJMB Retrofits
    Sep 2013
    changing the bose head unit ?
    hi i have just picked up an 07 a4 avant quattro S line 2.0tdi 170hp in phantom black with 'all' the extras, minus a couple of things im going to be adding myself, i have been lurking here a while and some of your beautiful cars have pushed me to get one myself!
    i want to change the standard head unit for something with a couple more features, (aux, bluetooth, usb) i have the bose single din, can't seem to find any numbers about on it, but i believe it is in the middle tier, what kind of harness would i need to connect it to a standard radio connection?
    parking sensors, now i havent ever had a car with them, but i think for this i would like to fit some, (quite abit longer and wider than my 01 diesel saxo! what should i be looking for? audi or some aftermarket ones
    edit: also i have noticed there is a switch under the steering wheel, like a small flick button, no idea what it does but it doesnt seem to do anything?
    i will be assembling a little build log of the mods i do to this car in the coming weeks, thankyou for any help
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    For things you don't recognise, always a good idea to add a picture.
    Either others will have similar, or will recognise the source and tell you what domain it comes from (electronics/motor DIY/automotive, etc)
    So for your radio and the switch, we look forward to seeing pictures!
    A4 B7 Cabrio 2007 2.0 TDi Black "Sport"
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    112
    Quote Originally Posted by edgey View Post
    Many on here will only go OEM; you can get (relatively) cheap ones and install them yourself for similar benefit.
    Main point that was not emphasised in the instructions for the after-market set I fitted to a previous car; the rear sensor sends out a 90° cone, and sees anything in that cone. Be sure to angle the sensors horizontal or above, so it does not see the road all the time.
  1. Which Bluetooth kit for S3 with Concert BOSE head unit
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2006, 19:38
  2. Changing the Symphony Head unit (Facia Adaptor)
    By Block 405 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2006, 12:57
  3. Bose Head Unit Audio input?
    By Fandango80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2006, 11:00
  4. S3 Bose Head unit turning off?
    By vernS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2006, 21:18
  5. how to remove bose head unit ?
    By Olly__K in forum In-Car Entertainment
    Last Post: 8th March 2005, 15:41
