Volks AutosEM Tuning
Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By jdp1962
  • 1 Post By rowdyboy
Thread: Brake bleeding
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Brake bleeding
    While changing my front pads today, I found a brake line corroded. I replaced it but now I have minimal braking, the pedal goes to the floor. I've bled the system several times but still nothing!!!
    Any ideas???
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    2,158
    how did you bleed the system?
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Someone pressing the pedal while I loosened the bleed nut.
    RNS-E retrofitted
    2,158
    Never tried that method, I either use gravity or one of these kits Gunson Eezibleed Automotive Fluids Bleed Kit - Machine Mart they work very well, just don't use to much pressure or the expansion tank will crack.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    It's how I've always done it on other cars. I just wondered if there was something different on Audis.
    Whats the gravity way?
    RNS-E retrofitted
    2,158
    Take the cap off the reservoir, then open the nipple and wait for the fluid to come out and keep topping up the reservoir I've done that on my A4 before, but I always use the Eezibleed system for the last few years.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    821
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Never heard of the gravity method before, I would of thought you'd need some sort of pressure behind it to force the fluid out. I usually use the Gunson Eezibleed kit.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    I phone the garage!
    A4_MaJiK likes this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    AudiB7Jay's Avatar
    Nov 2012
    374
    Quote Originally Posted by jdp1962 View Post
    I phone the garage!
    Both are valid methods of bleeding the system. To make it easier u should clamp the flexi hose then remove a brake pipe then fit the new one and tighten up then slacken off to bleed. As for cracking the reservoir. Impossible to do these days there built to take maximum pressure under foot.
    2,158
    reservoir don't take any pressure under braking, it's just there to hold extra brake fluid. To much pressure on the gunson kit and they will break.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    I phone the garage!
    I'm im too tight for that!!!
    Anyway, all sorted now, I think the constant pressure of the Gunson kit forced the last of the air out that pressing the brake just couldn't do.
    Cheers.
    jdp1962 likes this.
    RNS-E retrofitted
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    Quote Originally Posted by rowdyboy View Post
    I'm im too tight for that!!!.
    Heheh! I'm too useless and dangerous to do anything else!
    Apr 2013
    Aberdeenshire
    592
    Have you bled them in the correct order also did you have the peddle pressed down while the bleed nipple was tightened.
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Quote Originally Posted by Chillout View Post
    Yes mate, I did.
    As I said, all sorted now thanks.
    RNS-E retrofitted
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    The point of my post was that I don't bleed my brakes. I get someone who knows what they're doing to bleed them. So I'm guessing you didn't intend to quote me.
  1. Brake bleeding help!
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 21:27
  2. Brake Bleeding With No Diagnostic Plug
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2009, 06:12
  3. Brake Bleeding
    By GSXpress in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2007, 11:56
  4. Brake Bleeding
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2007, 12:49
  5. brake bleeding issues!!
    By mrj0ey in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2007, 21:52
