Sky InsuranceJMB Retrofits
Results 1 to 7 of 7
Like Tree4Likes
  • 3 Post By sidibear
  • 1 Post By NHN
Thread: HELP! Foreign Objects Between Dash & Windscreen
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Need some urgent help here as the noise is driving me nuts! Not sure if anybody else here has had this issue before, but long story cut short there are some plastic jewellery "stones" stuck in between my windscreen and dash. They slide around during cornering and is driving me insane LOL! Any ideas/solutions are welcome on how to get them out of there.
    Pictured below are the pesky little things:
    Thanks in advance, Az.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,313
    I'm sure you've probably already thought of this and don't want to do it but surely the best way is taking the dash apart.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Quote Originally Posted by DieselJake View Post
    Yea, was looking for an quicker solution tbh...
    Jul 2013
    74
    can you move the stones to one side of dash and maybe a hoover with a decent attachement get them out ? Or a couple pieces of flexible plastic to use a large tweezers . Havent looked down at the clearance between dash and windscreen.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,994
    Get a small Pritt type adhesive pad, cut it into 4 small squares, hold one edge ways in a pair of tweezers, squeeze to compress it into a lump, touch them with the pad and gently extract.
    NHN, scotty76 and A4_MaJiK like this.
    JSD 2.59
    Synergy-Solutions
    27,043
    Yeap some double sided sticky object ,so they can bond to when rolling about, then extract while stuck to.
    A4_MaJiK likes this.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    817
    Thanks for the advice guys, not had a chance to try them out as of yet. Had quite a busy weekend. Will let you know on the results/outcome once I've had the chance.
    Thanks again, Az.
  1. A little Audio help for OEM Sub and Amp wiring
    By 4NT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2012, 20:46
  2. Help removing centre console/dash 09 A4
    By Marv A4S-Line in forum In-Car Entertainment
    Last Post: 17th September 2009, 13:28
  3. Help removing centre console/dash 09 A4
    By Marv A4S-Line in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 14th September 2009, 21:36
  4. URGENT HELP needed, fault on dash!!
    By Booth_S4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2007, 17:04
  5. Help needed in fitting an amp.....
    By lawrence in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th January 2006, 00:23
