Volks AutosMonster Motorsport
Results 1 to 10 of 10
    Jul 2013
    North Wales
    15
    Add SNAKESASS on Facebook
    Red face A4 B7 2.0 TFSI HIGH REVING DURING GEAR CHANGE
    Hi all ,
    Just thought I would put a few minds at rest as it did mine. Just spent £950 on a new (vanos unit )cam balancer and the engine puuuurrrrrs. However , noticed that when I depressed the clutch the revs increased up to 1000 rpm when changing up from 1st to 2nd gear and about 600 rpm in all other gears. Thought at first I was driving like a vicar but read a few threads and the word clutch switch was mentioned.
    Just had one fitted for £25 , and now I realise that I wasn't driving like a vicar. Brilliant cheap fix , thanks to all the info available here and the time and effort taken by my fellow Audi fans writing it up.
    Happy dayz.
    Jun 2011
    Manchester
    248
    Where did you get the clutch switch from and do you have a part number please?
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
    Jul 2013
    North Wales
    15
    Quote Originally Posted by mancdan View Post
    Hi, looks like your car is identical to mine including the colour. I took the car to RC Motors on the Wrexham industrial estate. If you contact them on01978 661706 and ask for Mark he can provide you with the part number you require .
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    just get the clutch switch from audi under a tennsr and 5 mins to fit yourself
    Mar 2013
    Berkshire
    391
    The part number you are after is: 7H0927189 - Clutch Pedal Switch
    Jun 2011
    Manchester
    248
    Cheers Bez.
    BGB Engine Code.
    Jun 2011
    Manchester
    248
    Quote Originally Posted by Giosabcsl View Post
    Cheers Giosabcsl.
    BGB Engine Code.
    Jun 2011
    Manchester
    248
    OK, got part yesterday from Audi Stockport, £16.15 all in.
    Just fitted in less than 10 minutes.
    3 bolts to remove - 1 under the fuse cover at the side of steering wheel and 2 down towards pedals.
    Whole panel then just comes out with a bit of wiggling (the panel not me)
    Un-clip electrical connector and turn clutch switch anti-clockwise and remove.
    Insert new clutch switch, turn clockwise until you hear click, re-connect electrical connector.
    Put panel back in place and 3 bolts, jobs a good un!
    BGB Engine Code.
    Jul 2013
    North Wales
    15
    Has it solved your problem. Mines so much better, thought it was new clutch time but just a new switch was a massive relief.
    Jun 2011
    Manchester
    248
    I haven't really noticed much difference as my issue was not that obvious, but I haven't seen the revs sticking between gear changes yet since I changed it.
    BGB Engine Code.
  1. Gear change "Burp" on tfsi w/ S-tronic/DSG
    By A3SBQ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1 Week Ago, 13:20
  2. Grim findings during oil change
    By s3tby in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2012, 13:53
  3. HIGH REVING WHEN COLD
    By JOHNFAIRBROTHER in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2009, 14:11
  4. S3 - High Rev Gear Change Problem
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2009, 13:53
  5. 2.0TFSI clutch rough biting point during gear change
    By Lowridingaudi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2008, 11:26
