JMB RetrofitsEM Tuning
Results 1 to 11 of 11
    Sep 2013
    7
    B7 a4 2.0tdi 170... Massive mpg drop
    Morning AllBought the car in June and have regularly got 55 mpg doing my commute to work and back.Mid last week I noticed that the fuel remaining indicator in the car had dropped significantly from where it should be with the amount of fuel left in the tankA further 2 fill ups later and my mpg figures are 38 & 41 Mpg on the 2 tanksThe car is well serviced and although I've had a mass of problems with DPF removal, remapping, an egr cooler pipe, wheel bearings, drive shaft and having to replace both rear springs, the car has been running pretty well up to last week.The only significant change I can think of is outside air temp has fallen from the early to mid 20's to 14 & 15c... If the air intake temp sensor was faulty, would that cause the car to run rich and therefor cause this problem ? Has anyone got any other idea's ? Thanks in advance for any help you can give Car has 129k on it
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Outside temperature is significant, because of the time taken for the car to get up to running temperature from a cold start. How long is your commuting journey?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Sep 2013
    7
    Hi JDP....Normally about 30-35 mins and around 27 miles. I wouldn't have thought it would have been cold enough to make such a big difference but I'm happy to be corrected :D .... Do u think that could be it ? Is it better to leave it to warm up before setting off ?
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    Look at the usual suspects such as failing DPF and clogging EGR valve. Both will give you the symptoms your experiencing. Take it for a spirited drive and keep in 4th gear with revs high for about 15-20 mins ensuring the engine temp is optimum. This will start a manual regen and hopefully blow all the crap out of the DPF system.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Jonbooth View Post
    Definitely don't do that. The most efficient way to get an engine up to optimum operating temperature is by driving it (but gently of course). The drop in mpg you describe is probably too big to be explained solely by outside temperature reduction (especially over a 27 mile run). My commute is 11 miles, so it is more relevant.
    As Brodster says, check all the usual suspects.
    Sep 2013
    7
    Thanks for coming back to me... The DPF has been removed (which is why I needed a new egr cooler, they caught the pipe that drops from the cooler to the side of the block .... £300 .... Keeerrrrrching !!!) .... Are there any other symptoms that an egr valve might give... I'm getting a wining noise when I back of the throttle, my garage has said it's the veins (?) on the inlet manifold cause it's variable (sorry, haven't got the best knowledge of turbo's) Sounds a bit like Darth Vader's battle cruiser. Could that be the egr valve sticking and out if interest, would this cause an underboost fault ? Had an underboost fault when I first got the car in June but haven't seen anything of it since.
    Sep 2013
    7
    Just as a quick update to this, i removed and cleaned the Mass Air Sensor and reclipped the airbox back to the wing (clip had broken) and now its seems to be better... not as good as it was but now getting about 45mpg...
    What are the main things to check... from scouting round it appears to be the water temp sensor, the egr valve clean, the mass air sensor & the air intake manifold temp sensor. Is there anything else i should be looking at ?
    Apr 2013
    140
    I'm experiancing the same, but with a 140bhp cabriolet. I think its my cam shaft though.. :/
    Do you hear a weird sort of blowback noise coming from the the intake?
    Jul 2013
    7
    Quote Originally Posted by jimbooboo View Post
    Any update? I'm experiencing the same problem with a 2.0 TDI Cabrio with DFP removed.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,339
    Weather or driving it like a BMW.
    Jul 2013
    7
    Even beeing very careful can't get bellow 9,2L/100Km in the city (urban driving).
    Its a 2.0 TDI convertible with automatic gearbox.
  1. Expected Mpg 07 2.0Tdi 170 S line sport back DSG
    By paultaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2013, 18:12
  2. 07 170 2.0tdi DSG, worse mpg after new mechatronics
    Last Post: 23rd March 2013, 23:04
  3. new 2.0tdi 170
    By jonmusicman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th July 2006, 10:38
  4. New A3 2.0TDI 170 - prices
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th June 2006, 10:45
  5. 1.4TSi and 2.0TDi 170
    By mfspen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2006, 14:47
