Monster MotorsportVolks Autos
    Aug 2008
    Leeds
    152
    Question Rubbing Noise Coming from Power Steering - 2007 A4 2.0 TDi Cabrio - Help Please?
    Hi there,
    I've noticed recently that occasionally when at low speeds (usually manoeuvering the car in car parks) when turning left I seem to get a low down grumbling/rubbing sound coming from the power steering of our 2007 A4 2.0 TDi Cabrio.
    You can't really feel much through the steering itself but you can certainly hear it.
    Its strange in that it sounds more hydraulic than mechanical?!
    Any ideas what it might be? Is there anything I should be looking for?
    Any pointers would be a great help to hopefully avoid a large bill!
    J
    Jul 2012
    56
    First thing first check the fluid, if it's empty top it up then get looking for leaks.
    if it's full then it's probably the pump that's on it way out.
    Dec 2006
    Herne Bay, Kent
    67
    I had a 2006 2.0tdi from new a few years back and mine used to do it. It was all over forums at the time and I eventually had it fixed under warranty. I think they changed the power steering pipes but it was a few years back so I'm not definitely sure.
    2006 3.0 TDI Sline Cab, Auto, Phantom Black, Bose, Bluetooth, F & R PDC,
    Retrofit 2010 RNS-E, Aux In, Cruise, LED Numberplate Lights, RS4 RAB, Mtecc Drilled and Grooved Discs, Vredstein Ultrac Sessanta's
    To Do, auto lights, windscreen washers and dimming mirror.
  1. Noise from power steering
    By scottshere in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st October 2012, 20:41
  2. Ping Type Noise Coming From Front Steering. As Much Help As Poss Please :(
    By Phil_T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th May 2010, 18:30
  3. small annoying noise coming from center front air outlets?!
    By JCC1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2005, 10:00
  4. Strange "cluncking" noise coming from front
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 13:10
  5. loud humming noise coming from rear axle?
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2004, 13:18
