EM TuningBadger5
    May 2013
    Loss of power and black smoke
    Recently while driving up mortorway, realised heaters plug light on dashboard was flashing , at that moment engine response felt sluggish and black smoke started was coming out exhaust when I pushed the throttle all the way.. Got to a garage where he put a diagnostic on it but didn't give any faults (by this time heater plug light had gone out).....the car has hardly any power untill 3000rpm where the turbo kicks in and it's away like a scolded cat (turbo usually came in much beforen3000rpm) all while pumping black smoke out the exhaust..I've had a dpf delete and a remap(a4 2.0 tdi 170 07 plate)....mechanic has looked at it and got it back to standard software so he could diagnose it properly but still giving no faults.... He seems to think maybe turbo although he inspected it and thought it looked ok, or injector problem ( car has had injector recall less than 18 moths ago)....
    Sorry about the long post but not sure what to do next , any suggestions would be welcome....thanks
    Dec 2010
    223
    Change your fuel filter first, injector fault possible
  1. Loss of power and smoke
    By Thatch85 in forum Diesel forum
    Last Post: 1st October 2012, 10:27
  2. A6 C5 2.5TDi No power and White Smoke
    By dfh44 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th October 2010, 10:16
  3. Limp mode and black smoke
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 21:41
  4. Loss of power and shuddering engine intermittent...
    By Field in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2010, 17:03
  5. Knocking sound, loss of power and ECU light on
    By Stoosh in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2009, 21:21
