EM TuningAH Fabrications
Results 1 to 9 of 9
Thread: Oil Options?
    READER84's Avatar
    Jan 2013
    237
    Oil Options?
    Had a warning light come up this morning saying my oil level was minimum, what oil should i get to fill her back up? Halfords suggests 5w30? Should i use semi or fully synthetic? What brands should i look at or avoid? Thanks
    READER84's Avatar
    Jan 2013
    237
    54reg 2.0 tdi s-line by the way
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    do you know what oil is already in there ?
    READER84's Avatar
    Jan 2013
    237
    Nope
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    Fully synthetic that conforms to the Audi standard, Castrol, Mobil, Fuchs are what I use.
    READER84's Avatar
    Jan 2013
    237
    5w30 Fully? Think ill go with castrol, is edge any better than normal?
    leeoliver86's Avatar
    Sep 2013
    manchester
    20
    I've always used castrol edge 5w30 in my audi
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    Give Oilman a pm, he is the best knowledgeable one about oil on here.
    JSD 2.59
    Synergy-Solutions
    Molnboman's Avatar
    You shouldn't mix your oil up Matey If you are unsure. If you have the service book and the last service was a VAG dealer....good chance it will be VAG long life...should maybe say in the service book. For the same price a full tank of derv you could treat your pride and joy to an oil and filter change and put in some nice fresh gear to be on the safe side.
    Good Luck
    A
  1. Stripped oil drain sump bolt - repair options?
    By Scullies in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2013, 09:56
  2. Engine oil options
    By daz-20vt in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2013, 07:45
  3. Oil Catch Can, quality options to buy in the UK
    By mikem1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2012, 21:23
  4. High Mileage Synthetic Oil Options
    By ehuggins in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th May 2011, 08:34
  5. S3 Engine Oil change options? and how to?
    By Poke13 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2010, 13:41
