Chris NottVolks Autos
Results 1 to 13 of 13
Like Tree2Likes
  • 1 Post By Paul B7
  • 1 Post By adamss24
Thread: Can you remove the oil pump without an engine lift?
    May 2013
    7
    Hey guys,
    I'm proactively changing the 77mm to a 100mm hex with balancer shafts.
    2 questions:
    1) If the hex are just worn can I get away with just fitting a new hex without the balancer shafts?
    2) Can this be done without the requirement for a lift?
    May 2013
    7
    infact a better questions would be can you replace the hex without replace the shafts? and can the 100mm fit in the 77mm's place without modification?
    Jul 2007
    London
    3,072
    Nope to most of your questions ! You can remove the subframe but it will throw all suspension geometry out ! The hex can be replaced without taking the balancer shaft off- there's a circlip holding it in but you need a special puller that screws into the shaft- you will understand when you buy your replacement hex drive !
    FOR SALE:
    Jul 2007
    London
    3,072
    FOR SALE:
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Those are some of the scariest pictures I've ever seen, LOL
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    May 2013
    7
    mine hasn't failed yet, as i said its just a proactive measure. But is it the 6mm Hex that wears or the balance shaft aswell? Can i get away with just replacing the 6mm hex and run that for another 50k miles?
    Looks like a bit of a job! I'm thinking of selling the car now
    May 2013
    7
    Hi The hex key is hardend steel so wears out slower than the balance shaft, the balance shaft takes most of the wear as it is only mild steel.
    My advise would be to renew both parts, if you do this using the later 100mm key and balance shaft and not the 77mm key and shaft which yours will have, the wear problem will never arise
    KMB Parts Direct
    North East
    568
    Quote Originally Posted by adamss24 View Post
    Now here is someone who does know what he is doing. I liked seeing these pictures when they were first posted and they still make me look in awe . Good job well done if my memory serves me correct.
    jdp1962 likes this.
    Jul 2007
    London
    3,072
    I wished i took more snaps to be honest Paul but greasy fingers and digi cameras don't mix too well ! That's nothing mate, you should see when i rebuild engines, my garden and drive are like a garage shop ! Here's a few pictures- sorry for the hijack :
    jdp1962 likes this.
    FOR SALE:
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Paul is right; these pictures are awe-inspiring. But I still find them scary as well. I don't think I'd ever want to see my car looking like that.
    Jul 2007
    London
    3,072
    Them cars are just nuts and bolts and they are designed to come apart...one way ore the other!
    FOR SALE:
    North East
    568
    Quote Originally Posted by jdp1962 View Post
    My car has been like that but fortunately I wasn't there to see it...............bloody oil pumps !
    May 2009
    south yorkshire
    563
    forum member llamamoo does the oil pump drive ,thats who/where i got mine from .
  1. Can you tell if oil pump is working?
    By Filth in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2013, 12:02
  2. can you remove the amber lenses in the headlights
    By andymartin045 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th June 2011, 13:14
  3. Can you change the battery without losing the radio?
    By gadgesxi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2010, 17:11
  4. How do you remove the lower skirt trim?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2004, 19:50
  5. S3 How can you tell the BHP difference???
    By imported_dpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2004, 11:54
