Monster MotorsportChris Nott
Like Tree3Likes
  • 3 Post By NHN
Thread: Rs4 starter button Help needed
    Aug 2011
    10
    Hi guys. Having a crack fitting the button. Has any1 fitted this to thr a4 b7? Any help would be much appreciated. Searched forums but guides coming up for a3. I think they work differently?
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,333
    NHN's probably the man if you need it fitting. Doing it yourself this thread may come in handy Fitted RS4 push start button into B7 A4 not entirely sure but the user may have also listed a DIY somewhere.
    Aug 2011
    10
    Im doing it myself. Got illumination tested out a few wires & put in a few relays on different places but no joy. Any1 got a write-up to hand. Dont fancy putting console back together & re-stripping agn. Thanks
    27,072
    Yes its my mod originally, I had an S4 B6 to fit too, sold it & bought an 8P, fitted to that some while back now, memories lol.
    RS4 starter button is purely a push to touch with an illumination circuit of the interior night mood lighting when headlights are on.
    You need to intervene with the ignition wiring & find the correct signal wire that would either signal the steering module to the ecu/starter or the direct wire signalling ecu/starter.
    Multimeter is your best bet to find the wire that changes spec when starting the car, think of it as a manual relay that's actioned by your hand turning the barrel, so you need to find the wire supplying when key is turned & the wire it transmits onto.
    I didn't use a relay on my 8P, as its a momentary signal to start, I cant imagine the B6/7 is any different.
    Aug 2011
    10
    Cheers budd
    thts wot am gna do in da morn. Am not gna giv up till i get it wrkng.
    27,072
    Ok, but please use English, not text talk on here.
    jdp1962, DieselJake and GeoffDunk like this.
  1. Help needed which rs4 injectors and FRV for the 2.0 tfsi part numbers/advice
    By AARON77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2011, 18:36
  2. RS4 starter button retrofit
    By Fast,not furious in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th April 2009, 15:35
  3. B5 RS4 esp button problem! Help
    By launching_rs4 in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd February 2008, 02:57
  4. rs4 wheels help needed
    By markymarc in forum RS6 Forum
    Last Post: 1st May 2007, 11:08
  5. RS4 Bumper fitted to a S3 (Help Needed)
    By lUCKYS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2006, 00:41
