EM TuningBadger5
    Molnboman's Avatar
    Oil Vacumn Pump leak
    After a disastrous attempt to remove my Sump to replace the oil pick up filter, I have found the source of the oil weep on my engine at least. It's coming from the Oil Vacumn pump. Has anyone had a go at fixing this. I read in some other forums that it may be best to replace the pump completely but am hoping that's not going to be the case. As there is only about 4 - 5 inch clearance from the bulkhead....am not expecting it to be easy.
    Anyone had previous experience.
    Thanks in advance,
    Allan
    Jul 2013
    East Lancs
    46
    Sorry, no experience of this but I'm glad you've found the problem and hope the fix isn't too troublesome. Wish I could give you a better answer.
    Molnboman's Avatar
    Found this on another site.....not quite as bad as first thought but a new pump looks likely. I reckon this has happened as a result of the faulty pcv I was running over the past few months. Not a cheap part either!
    2.0 Vacuum Pump help
    Don't leave your knackered pcv too long......
    A
  1. TANDEM PUMP LEAKING & NOT SO GOOD NOISE
    By tommytonguedj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th May 2012, 14:03
  2. 1.8t water pump leak
    By neilA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th March 2011, 13:33
  3. AUM 1.8T dodgy oil pressure/pump ???
    By DionBullock in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2010, 18:20
  4. S3 BAM - Aux Water Pump Leaking!
    By audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2010, 19:02
  5. Aux Water Pump Leaking - S3 AMK Engine
    By jimbo_123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2008, 17:39
