Volks AutosAH Fabrications
    Sep 2013
    62
    front and rear brake discs + pads for 2.7 tdi
    What setup would people recommend for a4 b7 2.7 tdi saloon ?
    I think it is 288 rear and 320 front was thinking brembo but nextdaybrakes refunded me as they can not get brembo.
    Molnboman's Avatar
    I had a bad time with Mintex discs. They performed very badly and wouldn't recommend buying them. I have had Zimmermann's coated discs front and back since July and they appear to be working well. Otto Zimmermann Bremsscheiben GmbH - Zimmermann Brake Discs Brake Pads
    A
    Sep 2013
    62
    i seen on the forum good and bad reviews with mtec and mintex and pagid.
    Where did you order them from if you don't mind me asking, take it the fronts have integrated wear leads with them than attached to some kind of clip like ebc?
    Molnboman's Avatar
    Quote Originally Posted by etxeondo View Post
    I bought mine through a garage over here. I think you can buy them directly from Zimmermann but not 100% on that. Yeagh, the wear indicators were all there. After my experience with the Mintex ones which weren't the cheapest, it's worth paying a bit more for better discs imho....I wanted to go a full front S4 brake upgrade but the caliper carriers were far too expensive to justify that option so just went for the pads and discs and good quality brake fluid change too.
    A
  1. Front and Rear Brake Pads...
    By leeds2592 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2012, 12:22
  2. Ferodo DS2500 front and rear brake pads
    By downtothebone in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2012, 13:38
  3. Aftermarket Front and rear Anti Roll Bars for S3 8P: WANTED
    By S3-Dan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2010, 21:52
  4. B5 RS4 front and rear brakes
    By docurley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2009, 20:39
  5. Need A3 1.8 T front and rear brake rotors specs
    By lwen in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2003, 14:57
