EM TuningJMB Retrofits
    Aug 2013
    B7 Cabriolet roof problem
    Hi All
    I have a 2006 cab and I found hydraulic oil leaking from a strut when I opened the roof. I cleaned the oil away but the roof will not close so I have had to do this manually.
    Would the leak cause the pump to stop working? (oil level sensor?)
    How easy is it to top it up (so that I can prove or disprove my assumption) and then replace the strut.
    I have just sold the car and obviously need to get it working for the new owner before they collect.
    Any help would be gratefully received.
    Kind Regards
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    361
    Quote Originally Posted by English T View Post
    Hi All
    Kind Regards
    If there is no fluid then yes the roof will not function, which ram is leaking?
    To top the fluid up you have to remove the driverside boot lining, also I'd recommend to perform a commutator clean and brush check whilst you have it open. I've written a guide on this....
    Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
  1. A4 cabriolet roof problem.
    By pbranson in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2011, 20:30
  2. 2004 cabriolet roof problem
    By cvro4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2011, 10:41
  3. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
  4. Cabriolet Roof Problem - Please Help!
    By StuartC in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:22
  5. Audi Cabriolet roof problem
    By RoStar in forum Classic Audi Forum
    Last Post: 28th March 2004, 18:47
