Monster MotorsportEM Tuning
Results 1 to 7 of 7
    Aug 2013
    6
    Audi a4 B7 2005 Aircon fault code
    Hi Can someone please explain to me what a fault code P1635 means and how to rectify it.Thanks
    26,750
    Check your fuses.
    Aug 2013
    6
    Check your fuses.
    Fuses is ok ,what else can I check
    26,750
    Wiring, climate unit, functionality, you haven't advised of any faults, just a code.
    Aug 2013
    6
    Hi the aircon blows wind,the heater is working,the gas is full,but it do not make cold air.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,929
    is the ECON light lit up ?
    Aug 2013
    6
    No the Econ light is off
  1. Audi a3 1.8t major fault codes
    By Stretchykid in forum The Welcome Section
    Last Post: 8th June 2013, 08:57
  2. m8s audi 1.9 tdi 17965 fault code
    By tdi-man in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2011, 18:50
  3. Audi A4 Avant 1.8T Fault code help
    By Wilo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th May 2010, 19:27
  4. audi a4 b6 1.8t fault code
    By mrjheeta in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th December 2008, 18:06
  5. Aircon fault code 18.3 - how to fix it?
    By koonl in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th October 2006, 19:26
