JMB RetrofitsChris Nott
Like Tree2Likes
  • 2 Post By jdp1962
Thread: Diesel particulate filter obstructed light has came on
    Apr 2013
    Bristol
    153
    Basically came on this morning car still runs no different than usual but what to do now? Not sure if this is right but is this where you drive it on the motorway at a certain amount of revs and mph then clears on its own?
    27,129
    Could be doing a regen, a good 2-3k blast on a dual carriageway for 20 minutes may help.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,703
    Quote Originally Posted by Audibritz View Post
    There should be some pretty specific instructions in the owner's manual on how to clear it.
    NHN and Dannykn9 like this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Apr 2013
    Bristol
    153
    Went to the barbers had me barnet cut got back to the car and the light is off and done about 20 miles since. Abit weird
    27,129
    Not really, its probably completed the regen now.
    Jun 2011
    Wellingborough
    1,174
    Did the B7's have a DPF? only the 170's maybe.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
  1. DIESEL PARTICULATE FILTER!!
    By miw615 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2013, 07:33
  2. Wynn's Diesel Particulate Filter Cleaner
    By icekay in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2012, 19:52
  3. Diesel particulate filter
    By Chris71 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd August 2011, 19:25
  4. Replies: 5
    Last Post: 16th March 2011, 15:07
  5. How to clear a blocked diesel particulate filter
    By Matty1234 in forum Diesel forum
    Last Post: 30th May 2010, 09:54
