Badger5Volks Autos
Results 1 to 25 of 25
Like Tree8Likes
  • 3 Post By jdp1962
  • 2 Post By sidibear
  • 1 Post By sidibear
  • 1 Post By Andy27168
  • 1 Post By bez101
Thread: Removing the glovebox
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    I know there are about 6 - 8 bolts but what do I need to remove them? My car isn't here so I can't go out and look. Also I have the CD changer in there, how easy is it to take it out and re install?
    08 B7 Avant.
    Thank you.
    JSD 2.59
    Synergy-Solutions
    27,097
    Morning shorty, changer is removed with 2 radio key holes at the bottom, slides out & disconnect at rear, refit in reverse with no keys
    Glovebox has about 6 x 8mm hex headed bolts to remove, 1 is hidden behind the changer so remove this 1st.
    What's the crack, problems?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Morning shorty?
    Is it wise to make personal comments about a man with access to firearms?
    NHN, sidibear and Sandra like this.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    27,097
    He'd need a trident to get this far atm, maybe when back I'll revise my height comment lol (he's not short at all)
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    So I need radio keys?
    I am fitting the cooling pipe from the aircon to cool the glovebox, maybe do it this weekend if I get chance, or manage to collect the bits from Listers.
    Shorty? Beats being called Tea *****
    Sandra and Geebo like this.
    JSD 2.59
    Synergy-Solutions
    27,097
    Yesh you do to release the side clips matey, also the cooling pipe sucks arse, had it on our S4 B6 & you need the specific glovebox with fridge area to make it even remotely effective or do you have other ideas like cooling firearms lol.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    I need to keep my Epipen cooler, it lives in the glovebox. If it gets too hot it affects it. Had to replace three this year so far. The cost so far equals the parts I need so for me its a worthwhile mod even if it only cools it by a few degrees.
    I will gets some radio keys when (if) I get to Listers today.
    JSD 2.59
    Synergy-Solutions
    27,097
    Ah yes fairly important then, but you realise aircon has to be on at all times to maintain cooling effect, sorry if sucking eggs here, but its not a separate system, I personally would of suggested a boot cooler box via 12v socket.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    I never have the aircon off, that why Tracey wears a fleece in the car all the time
    Sandra likes this.
    JSD 2.59
    Synergy-Solutions
    27,097
    Problem with that is when you do have heat up, would it affect the item even more with the hose fitted as it would be directly on the item in question, whereas before it may have been shielded by heat or are we talking even in the coldest of winters you have it on freezing lol.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    I have it on cold most of the time, rarely gets set above 21° even in winter. On a previous post about this mod it was said that the pipe take off is from the A/C matrix and is always cold as its before the heater matrix.
    Post 28
    Chilled glove box
    JSD 2.59
    Synergy-Solutions
    27,097
    I don't recall that tbh, but I maybe mistaken, mine was subject to whatever condition climate was on, but hey all up for learning more
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    If I get it fitted over the weekend I will let you know if it works or not.
    Parts collected and they were kind enough to give me a couple of sets of radio keys.
    JSD 2.59
    Synergy-Solutions
    Mar 2013
    Southampton
    128
    Hi,
    Having recently fitted the chilled glove box option on my B7 2006, I can confirm that it is always cool as long as the A/C is running regardless of temp settings.
    Really simple to do took me about an hour, that was to fit the chilled glove box lining as well.
    sidibear likes this.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    yes it stays cold in there even with full heat on
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    All done. Took about 30 minutes, very easy to do.
    JSD 2.59
    Synergy-Solutions
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Airbag light is staying on. Dis says passenger airbag on, but light remains lit. Light on buttons under the central air vents isn't on.
    Any ideas?
    JSD 2.59
    Synergy-Solutions
    27,097
    Just needs clearing with vcds matey
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Thanks Nige, I was hoping it was something simple.
    I will have to put up with it for a while until I can get someone to shift it.
    JSD 2.59
    Synergy-Solutions
    bez101's Avatar
    Jul 2008
    8,491
    ill be around m42 m5 saturday if any good
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Bez,
    I have to go to Halesowen on Saturday, near Mucklow Hill. Anywhere near where you will be?
    JSD 2.59
    Synergy-Solutions
    bez101's Avatar
    Jul 2008
    8,491
    ill be passins on the motorways on way to s wales
    so would be a service station if your near one
    tamworth
    hopwood park
    Strensham Service
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    Thanks Bez, what time roughly would you be at Hopwood?
    JSD 2.59
    Synergy-Solutions
    bez101's Avatar
    Jul 2008
    8,491
    Hopwood around 1230pm
    or there abouts depending on any road works.
    sidibear's Avatar
    Nov 2008
    Birmingham UK
    2,003
    I will have to get back to you to confirm. Have to get to Makro Sat morning, maybe able to meet you on my way back if I take the long route.
    JSD 2.59
    Synergy-Solutions
  1. Removing the rear window wiper...
    By imported_trident21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2005, 14:48
  2. How do i remove the front and rear bumpers
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 16:37
  3. How do you remove the lower skirt trim?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2004, 19:50
  4. Removing the grill?
    Last Post: 27th October 2004, 00:52
  5. how do i remove the network logo...
    By ooooaudi in forum General Chat
    Last Post: 15th May 2003, 14:39
