AH FabricationsEM Tuning
Results 1 to 17 of 17
    Danny-boy's Avatar
    Jan 2013
    477
    A4 B7 2.0 TFSi - DV Noise
    Hi all,
    Since I bought my car, I noticed what I assume to be a noisy diverter valve.
    Assumed it was split, so changed to a rev D. Power jumped hugely, but the noise is still apparent.
    The noise in question is a fast ticking / whirring noise when revs are dropping. It happens when driving and stationary, and is only audible with the windows down.
    I have just fitted a BSR Optiflow induction kit, and the sound is still rather annoying - more apparent today as I was testing the BSR with the windows down.
    Questions........
    1. From what I have read, the noise is normal. Anybody else experience this?
    2. Would an aftermarket DV sort this out? If so, which one?
    I'm not after a loud dump valve or anything like that, the more silent the better.
    Dan
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,910
    the 2.0fsit can sound derv like
    but then again ot could be the chain makeing the noise
    i had a ticking on mine for ages changed loads of parts ended up been the inlet mani.
    Molnboman's Avatar
    Am wae Bez on this....the 2.0t engine are noisey f#ckers!...am pretty sure a new DV wouldn't cure any rattle as such. Probably hear the rattles more as a result of you fitting the induction kit too. Can you upload a YT clip....and I can compare it to my rattler for reference if you like.
    A
    Danny-boy's Avatar
    Jan 2013
    477
    Hi gents, thanks for the responses.
    I'm not sure how to post up a soundclip, I just recorded it with my iphone and it's in an M4a format.
    I can email it if you PM me your email address.
    Sorry to be a pain.
    Dan
    Danny-boy's Avatar
    Jan 2013
    477
    Molnboman's Avatar
    Listened to your sound clip Danny and my car never sounded like that with it's knackered DV. Sorry I can't give you anymore than that. Perhaps someone else will be able to help with this one.
    Good Luck
    A
    Danny-boy's Avatar
    Jan 2013
    477
    Thanks Molnboman, appreciate you taking a listen.
    It's been like that since I bought it 9 months ago, so I'd like to get to the bottom of it and solve it if possible.
    I changed the DV about 8 weeks ago and the noise didn't change, so I'm not surprised its not DV related.
    Thanks again.
    Anybody else have a view?
    craigcull's Avatar
    Oct 2011
    Leeds uk
    989
    Visit craigcull's Youtube Channel
    Quote Originally Posted by Danny-boy View Post
    Thanks again.
    hi Danny, just to confirm really that mine never sounded like that either. But to me it sounds more like chain slap of some sort. I would be tempted to get the chain and tensioner done sooner rather than later. Sounds like the tensioner isn't taking up the slack. All I found with the bsr Optiflow was just more intake sound. Nothing like the sound lip I've just played. It's worth getting it done just to illiminate it from any enquiries.
    Danny-boy's Avatar
    Jan 2013
    477
    Cam chain?
    craigcull's Avatar
    Oct 2011
    Leeds uk
    989
    Cam chain?
    gonna text you now mate
    Danny-boy's Avatar
    Jan 2013
    477
    Cheers Craig, appreciate our discussion.
    Anybody else agree with cam chain slap?
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by sewell10 View Post
    Had mine done at the dealers still sounds like a diesel when warm
    How much did it cost you buddy?
    My noise is only when revs are on the way down, not all the time.
    Molnboman's Avatar
    Can I chuck in my tuppence worth again.....I didn't look at your earlier posts...was the sound there before the open filter?....Cause to me it just sounds like an engine with an open air flow. My Saab Aero had a BSR optiflow fitted and the engine sounded just like that.
    BR
    A
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by Molnboman View Post
    BR
    A
    Hi, yes the sound was there before the BSR, and it's still the same.
    The only reason I mentioned it was because I was driving with the window down to hear what the BSR sounded like which made the noise more obvious.
    Having done more reading, I'm not the first to have this sound. Others have had it exactly the same.
    Their conclusion was wastegate actuator rod or N75 valve. In the case of the WAR, it's fixed by a new turbo!!!
    Molnboman's Avatar
    Oh, ok Danny.....but a Turbo as a fix.....Jaysus, you wanna make sure that's gonna fix it.....but saying that, it's not the most expensive part to buy or fix in the big scheme of things....but it does take up a good few beer tokens!
    Good Luck,
    A
    craigcull's Avatar
    Oct 2011
    Leeds uk
    989
    To be fair mine also still sounds like a diesel, but that's just the nature of the engine. It quietened down by 30% with the new chain and tensioner.
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
    bowen's Avatar
    Mar 2011
    456
    Did you ever get this fixed Danny?
    Audi A4 B7 SE S line TFSI Quattro.
  1. 2.0 Litre TFSI - Knocking noise in head
    By Alex C in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th January 2013, 18:11
  2. engine noise on 2.0 tfsi
    By jordychris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2012, 15:59
  3. 2.0 tfsi flutter noise
    By Leon tfsi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd October 2011, 17:58
  4. Front suspension noise (both sides) Audi A4 TFSI Quattro
    By Rob Hill in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd March 2010, 19:49
  5. Phat noise unit?
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 18:33
