AH FabricationsBadger5
Results 1 to 13 of 13
    MGTURBOM's Avatar
    Oct 2006
    76
    DPF Problems again!!
    OK folks getting a bit desperate now for a cure. Driving back from Notts to Derby last night the DPF light came on. Despite my best efforts doing the right things as instructed I can't get it to go out. I've been have problems with the car for over a year now. The main dealers can't seem to fix it!!
    Last night I was able to briefly put the light out turning the ignition of and on, this would pop the flashing glow plug light on then send the car into limp mode. Turn the ignition off again whilst moving cleared this light. About two minutes later the dpf light is on but the car performs as normal, not in limp mode.
    It had a air pressure sensor changed. The car was at the main dealer only two days ago. The only fault its displaying is intermittent low fuel pressure. Its had a new fuel filter fiitted on Wednesday as this was overdue but the problem has been ongoing. Can anyone out there help?
    Never owned a car that has been so troublesome!
    Tiffy's Avatar
    Mar 2013
    Warwick
    354
    Get it removed and mapped out.....job done
    2007 Audi A4 B7 S-Line Avant 170 TDi Special "Black" Edition
    Genuine 19" x 9 Bentley GTC 5 Spokes
    Full Interior LED Light upgrade
    Ambiant "Submarine" Interior lighting
    Seat Leon Cupra R Splitter
    LED rear NumberPlate Upgrade
    Headlight, Fog Light and Side Light White Light Upgrades
    Eibach SportLine Springs 50/40
    Privacy Glass
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Unfortunately you are never going to cure it, these engines are incredibly troublesome with DPFs
    It needs removing. We have a lot of experience with these. Drop me an email or give me a call (no on website) if you want a chat about it. I can explain your options
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    MGTURBOM's Avatar
    Oct 2006
    76
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    I hear what your saying about removing it. I like the fact the car runs so clean though and your don't get the black smoke. I spoke to BVR yesterday and they were of the opinion that the 3.0tdi should'nt be an issue with DPF problems. I've run the car this morning..tried to get it to regen. I got a little frustrated so acceleratedhard in third, cut the ignition for a moment then back on. DPF light is now out again and has stayed off since.Hasn't gone into limp mode either. I presume it must be electrical and the jolt may have disturbed somthing. Probalby not good for the car doing this but by luck or coincidence it seems to have done somthing.....
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    I dont understand why you've been putting up with this for over a year?
    Have the DPF removed..
    Transforms the car, especially if you have the 3.0 engine.
    Car runs better.
    Less damage done to you're turbo.
    Had mine done and 100% better than it was. There is NO black smoke when driving.
    if you want a car that is "clean" buy a hybrid or electric?
    T3nnant's Avatar
    Jan 2013
    Newcastle
    363
    Oh and as for you're "regen" attempt.... The car needs to be HOT and very hot.
    accelerating hard wont do it, Take it on the motorway... stick in in 3rd and keep the revs high for 5-10 mile.
    Jul 2013
    Peterhead
    16
    I had same problem as you, Got Dpf removed and re-map done last weekend by Broadster and a stage 1 done also got EGR removal. Best thing i done now got 220bhp and better MPG.
    Nod
    MGTURBOM's Avatar
    Oct 2006
    76
    Quote Originally Posted by T3nnant View Post
    Car runs better.
    I am well aware of the procedures for carrying out a correct regeneration. My explanation suggests it may not be the common usual dpf problems. I can't see how the dpf would also cause sudden hesitation then drop into limp mode, which it does on a occasion! Its all well and good saying yeah lets get rid of the dpf and re-map but until I can diagnose the fault that is causing the car to fault its not my first plan. I was hoping everyone else would buy an electric car to leave me plenty of black stuff for a V8........
    Jan 2012
    Stockport, Cheshire
    748
    Yes, they do run very clean with the DPF, that's agreed. When the DPF is new and totally clear they can work well. However the amount of regens required burns a lot of extra fuel as the car gets older. This together with the extra work required to be carried out by the engine to force gas through the DPF means that any emissions savings are cancelled out.
    The map can be calibrated in such away that there is no smoke without the DPF by running the car lean. This ensures all fuel is completely burnt and hence no soot
    Rick
    MGTURBOM's Avatar
    Oct 2006
    76
    Audi carried out a bit of investigation work whilst changing the water pump. The technicial suggests the car may have been re-mapped as he explained he hadn't ever driven one that has gone quite so well before. He said this could be the cause of dpf faults popping up as the result of the map....
    Jan 2012
    Stockport, Cheshire
    748
    if the DPF is still there, then any remap needs to be done incredibly carefully so as not to exaggerate DPF issues. 185bhp is your limit with it on reliability wise. To be honest, the Audi tech should be able to do some logs and check whether it was mapped if he could really be bothered....
    Rick
    Apr 2013
    Bristol
    148
    My dpf came on about a week ago only for 30mins and just switched off on its own and ain't seen it since, if i ever pull away hard in first the black smoke that comes out the back is unbelievable. If I get a remap done and get it removed what downfalls is there? I read people seem to get the clutch slipping and turbo going a few months after the map because the standard parts isn't built to cope with the torque?
  1. DPF Problems on 170
    By Fingers in forum Diesel forum
    Last Post: 20th July 2010, 22:04
  2. Wheel Speed Sensor Problem...... again!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2009, 18:38
  3. 52 TDI problem - again
    By bonerp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2007, 08:09
  4. AUDI DPF Problems
    By s18ter in forum Rants & Raves
    Last Post: 29th November 2007, 14:35
  5. Concert Volume problem ( again ) and code for new one...
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2006, 21:14
