EM TuningChris Nott
Results 1 to 7 of 7
    Jul 2013
    East Lancs
    46
    Has my car been tampered with? . . .
    . . . and not in a welcome or useful way! I've had the car scanned with VCDS to try and get to the bottom of some problems that nobody can seem to solve. So, expecting (and hoping for) an error code to reveal something insightful I get this:
    000000 - SAE - Reserved by Document ISO 15031-6
    P0000 - 006 - 2005 - Intermittent
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 37
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1984 / min
    Torque: 144.0 Nm
    Text: Kein MEASVALUE verfuegbar
    Raw, Form. N / A: 000 000 000
    Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6CD392611C222C78EC3
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113) 41-00 - Blocked or No Voltage
    The first error code is weird, and there's not much on google to explain it, other than some non-English forums in Russian, German, Romanian, Hungarian . . . et. al. Using google translate with some amusing results it appears that the guy who posted it on the German forum appears to be getting told off for deleting his DPF. And then I came across an English post about somebody trying to fix a Golf TDI 170 with the same error code and the response says:
    Sounds like someone has used a 'DPF delete' tool like ECUsafe (or similar) on it. If they have done that then they have probably messed around with the fuel and boost maps too. You could try switching the ECU with a known good unmodified one and see what codes it throws?
    My problems are excessive black smoke, lumpy idle, hesitation at about 2,000 rpm (a slight flat spot), very easy to stall when cold and just turned on but seems okay once it's warmed up (this is a very new problem).
    I've only had the car 6 weeks. I'm starting to think it's no wonder people can't find anything wrong with the engine because the problem might be the ECU! Has anybody seen this error code before? Do you think it looks like somebody could have tampered with the ECU/map? Is there a quick and inexpensive way of testing the current map on the car or returning it to standard?
    I feel violated, like I need to take the car for a long wash!
    All insight is greatly appreciated because I don't know what to do next.
    Jun 2011
    Great Melton Norfolk
    1,356
    Did you buy it privately or from a dealer?
    Jul 2013
    East Lancs
    46
    Bought it from a dealer but they've already taken it to Audi and an independent garage and both have said there's nothing wrong with it even though they admit it smokes a lot and has a lumpy idle. Now I fear they may have been looking at the wrong part of the car though!
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    827
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Looks like your recirculation flap (for the AC system) is stuck?
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Might be helpful to post the full text of the VCDS scan for all controllers.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Jul 2013
    East Lancs
    46
    Hi Dave, I'll post the full VCDS scan again as it's not showing correctly on my netbook!
    Jul 2013
    East Lancs
    46
    Hopefully this will display correctly:
    Monday,12,August,2013,18:23:37:43483
    VCDS Version: Release 11.11.6
    Data version: 20121223
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E38A070466 Mileage: 141510km/87930miles
    Address 01: Engine Labels: 03G-906-018-BRD.clb
    Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ
    Component: R4 2.0l PPD1.3 9973
    Revision: --H43--- Serial number: XXXXXXXXXXXXXX
    Coding: 0000172
    Shop #: WSC 00191 264 15243
    VCID: 74E38A011712F4B8343
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 37
    Reset counter: 40
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1984 /min
    Torque: 144.0 Nm
    Text: Kein Messwert verfuegbar
    Raw, Form. N/A: 000 000 000
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
    Component: ESP8 quattro H06 0140
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004405
    Shop #: WSC 06325 000 00000
    VCID: 2E575869B9BE9E68827
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 N
    Component: int. Lastmodul ECE 0907
    Coding: 01001
    Shop #: WSC 65536
    VCID: 3D756F2537D875F00BD
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H14 4230
    Revision: 91H14423 Serial number: 0036M0G9UVPD
    Coding: 0031612
    VCID: 3B71613D7ACC7BC0359
    1 Fault Found:
    01316 - ABS Control Module
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 1048575 km
    Time Indication: 0
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0701
    Coding: 04011
    Shop #: WSC 06325
    VCID: 418D13D54B2011106F5
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 982 M HW: 8E0 920 982 M
    Component: KOMBI+WFS 4 H10 0200
    Revision: 0200 Serial number: 00000000000000
    Coding: 0007418
    Shop #: WSC 00667 210 03906
    VCID: 387B7E3148FA50D8D8B
    Part No: 8E0 920 982 M
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
    Component: RNS-E HIGH EU H74 0650
    Revision: 04S Serial number: AUZBZ7G1146576
    Coding: 0309717
    VCID: 326F4C19AE86BA88E6F
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBD1117D992CAB40659
    No Faults Found
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CQ
    Component: Komfortgerát T3B 4336
    Coding: 06895
    Shop #: WSC 06325
    VCID: 820F5CD98EA64A08B6F
    Subsystem 1 - Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0606
    Subsystem 2 - Part No: 8E2959801F
    Component: Tõrsteuer.BF BRM 0606
    Subsystem 3 - Part No: 8E0959801E
    Component: Tõrsteuer.HL BRM 0606
    Subsystem 4 - Part No: 8E0959802E
    Component: Tõrsteuer.HR BRM 0606
    1 Fault Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0309717
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
    Component: Parkhilfe 4-Kan H06 0010
    Revision: 00H06000 Serial number: 00067802020723
    Coding: 0000104
    VCID: 316D4315AB8081909F5
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
    Component: FSE_255x BT H26 0350
    Revision: 00000000 Serial number: 00000005240933
    Coding: 0011822
    VCID: 44831AC104320438443
  1. Has my car been mapped?
    By feck_on_a_stick in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th February 2012, 22:07
  2. has anyone ever been brave with the cars?
    By ja3mie in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2011, 20:03
  3. Has this car been clocked?
    By d4mo in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th September 2009, 13:19
  4. Has my future car been "Clocked"?
    By bioharry in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2004, 22:31
  5. Has my car been lowered?
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2004, 23:05
