EM TuningAH Fabrications
Results 1 to 10 of 10
    Nov 2008
    389
    Anyone got a Hunter printout they could share?
    Just wondering if anyone could share a scan of their Hunter 4 wheel alignment printout for a B7 A4 Quattro (Avant - but not sure this makes a difference) ?
    Just spotted that my local place ran mine through the system as a B8 and wondered whether that should make any difference to me or not. Its a faff on to take it back unless I really need to but if the acceptable values differ on a B8 vs B7 then I'll argue it back at them :-(
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    how does the drive feel ?
    my pal uses the hunter and not all car specs are listed
    so he goes on the next best spec
    Nov 2008
    389
    I've had uneven wear on the passenger front (inside) so I was surprised when everything came up green on the Hunter. For once I wanted to spend more money on an adjustment :-)
    bez101's Avatar
    Jul 2008
    8,510
    if i get to the garage later
    ill check both what year engine spec is your car
    then i compare both b7 an b8 for you
    Nov 2008
    389
    Cheers fella. Apologies for the delay- Tapatalk failed to be able to reply :-(
    Its a 08 plate 2.0TDI Quattro Avant. Much appreciated.
    Apr 2013
    Outer Manchester
    34
    I've got a recent one of mine, will try to photograph it later for you bud
    /// B7 Avant 'Quartzgrau'
    flickr
    Nov 2008
    389
    Thanks all.
    Apr 2013
    Outer Manchester
    34
    Here you go Phil
    flickr
    Nov 2008
    389
    Cheers fella. Mine looks pretty different (could just be formatting/older software ?) - I see that yours specifically says sports suspension whereas not only does mine say B8 but standard suspension too which is also incorrect as its an s-line.
    Nov 2008
    389
    I think the inner wear and rotational road noise that is occurring looks like it should be linked to a camber mis-alignment? But even though not everything stacks up on my printout it looks it is within tolerance?
  1. Anyone on here think that they could do this?
    By S3-Oski in forum You Tube Links
    Last Post: 17th April 2011, 22:30
  2. anyone got a symphony stereo they wanna sell ?
    By olliea3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2011, 11:24
  3. Anyone got an RNS-e they are looking to part company with ?
    By stevereid in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2011, 20:20
  4. Anyone got an original 1.8TQ exhaust they don't want?
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2008, 16:33
  5. Anyone got a Symphony II they want to sell?
    By terrymcg in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th November 2007, 14:42
