Badger5Volks Autos
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By gupsterg
  • 1 Post By tuffy
Thread: 2006 avant brake disc sizes
    May 2011
    Suffolk
    310
    Hi all
    Been emailing Mtec regarding a new set of discs a pads for my 2006 2.0 TDI Avant. They are telling me there are two sizes of discs 288mm and 312mm before I remove the wheel to measure (which Mtec suggested) do anyone know which diameter is the correct one for the mentioned car?,
    Thanks.
    Sep 2010
    Telford/Shropshire
    367
    Hi.your best bet is to take wheel of and measure the discs to be honest.
    or try to give call to your local Audi dealership with your chassis number,maybe they can tell you which of the two sizes mentioned is Yours.
    Proud owner of a:
    2.0T FSI quattro A4 S-line (saloon)
    Build thread
    http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b7-chassis/192911-just-another-build-thread.html
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    Follow ESD1711 On Twitter Visit ESD1711's Instagram Channel
    If its the 140bhp one you have, it'll most likely be the 288mm disc. Suspect the 312 is for the Quattro or the 170 perhaps.
    You're probably best to check to be sure though cos i'm only talking from my experience of my car.
    You get a similar headache with the rears in that it could be a few sizes for those too!!
    I bught from Mtec recently too though and i'm very happy with the service and the product though, so buy with confidence
    May 2011
    Suffolk
    310
    Quote Originally Posted by ESD1711 View Post
    Thanks mate.
    Mine is the 170.. So you'd say it's best to remove the wheel a measure to be sure?
    ESD1711's Avatar
    Mar 2013
    Edinburgh
    500
    Yeah mate, i'd reckon so - best to make sure.
    Whap a wheel off and check. Its not necessarily the easiest thing to measure accurately while its on the car, but you should be able to tell close enough whether its 288 or 312.
    I found it easiest with the help of a mate - we held a couple of bits of welding rod across the top and bottom of the disc and measured the distance between the two rods. That way the centre of the disc doesnt get in the way
    Sep 2008
    Nuneaton, Mids
    242
    I had the same issue but measured my 170 discs whilst I had the chance when fitting my coils and they were indeed 312mm
    Macdoon's Avatar
    Essex
    1,569
    170 and mine were 312 when measured
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Quote Originally Posted by tuffy View Post
    ... before I remove the wheel to measure (which Mtec suggested) do anyone know which diameter is the correct one for the mentioned car?
    Hi,
    There should be a data sticker either in your spare wheel well or in your service log book ...
    Enter data from that here Link:- PlanetVAG.com - VW & Audi PR Code Search
    There is also a guide on that webpage about what I'm instructing you on ...
    For instance my car has a PR code of 1LG for front and 1KD for rear ...
    Next post your PR code and I'll tell you size or you go on say eurocarparts site and enter number plate and cross ref the PR code in the suggested disc's and you will have your size from the specs there ...
    Stringster likes this.
    May 2011
    Suffolk
    310
    Quote Originally Posted by gupsterg View Post
    Hi,
    Thanks a lot for that buddy.....The code its showing for the front are 1LT and 1KP for the rears
    gupsterg's Avatar
    Jun 2012
    279
    1LT = 312mm x 25mm VAG P/N: 8E0 615 301 R
    1KP = 255mm x 12mm VAG P/N: 8E0 615 601 Q
    May 2011
    Suffolk
    310
    Thanks mate. Very helpful
    gupsterg likes this.
    May 2012
    Kings Lynn
    912
    Will the 170 312 front discs and calipers be ok to use on a 140 2005 a4? without having to fit anything else.
    I have 19's and the 288 looks slightly small lol....
    Current - 2006 B7 A4 S Line Saloon 2.0T TFSI Special Edition, Unicorn stage 1 remap, Metallic Dolphin Grey, 18" TTRS Rotors, Ferrari Red front/rear Calipers, 3.5" Powerflow tailpipes, BOSE, Cupra R splitter, Chrome grille slats, S4 Mirror covers, Black/silver leather interior, Debadged, Arm rest delete, LED plate lights, Dectane LED Red/Crystal tail lights, HID 6k, RS 4 pedals, Rev D D/V, APR snub mount, NGK 7s
    Gone - 2005 B7 A4 Avant 2.0 TDI
    Jan 2013
    Moray
    228
    Tuffy - i had 312mm discs on mine before the upgrade. The disc bells had vent holes in them. Running 321mm set up with allow calipers and greenstuff pads, MUCH better stopping power now :D
    Audi A4 (B7) 2.0TDi S-Line Avant Quattro - Steve Edition in Lava Grey
    BBS Wheels|arm rest|ambipur|345mm S4 brakes|PiperX panel filter|cupra R splitter|Greenstuff Pads|Retrofit Cruise control/DIS|Retrofit Audi Phone|Dension iPod|
    Full VCDS equipped for the Moray area
    gupsterg's Avatar
    Jun 2012
    279
    Quote Originally Posted by Av4nt View Post
    288mm system have PR code 1LB , 1LE is by ATE
    312mm system have PR code 1LT , 1LF is by ATE
    So they share same tandem brake master cylinder, brake servo , regardless of engine ...
    What you will need to do is recode ABS system (module 03), look under coding here Link:- Audi Portal: ECU Diagnostic . Audi A4 8E (2001-2008) . ABS Brakes J104
  1. Front brake disc size for 2006 A3 2.0TDI 140 FWD manual?
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2011, 18:50
  2. Brake disc sizes 2.0 tdi sport
    By mozza1202 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2011, 16:31
  3. 3.2 Front Brake Disc Size
    By edition in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2009, 18:32
  4. Brake Disc Sizes
    By ronny in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2008, 10:10
  5. S4 front brake disc size?
    By Dan Gliballs in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th September 2006, 12:35
