Results 1 to 9 of 9
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    722
    Jammed electric fan!!! HELP. Scan included
    My belt split the other week and at the weekend I noticed the fan wasn't running (temp went above half way for the 1st time) So had a look and its got some belt wrapped in it. Tried pulling it out but no luck. The fan Is stiff but can be turned by hand. My mate says chances are the fans burnt out and I should order a new one??? Obviously it looks a big job to get to.
    Running a scan I got this:
    2 Faults Found:
    006449 - Coolant Fan Control Module (J293)
    P1931 - 009 - Malfunction
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 24
    Reset counter: 40
    Mileage: 152527 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2464 /min
    Mass Air / Rev.: 114.5 mg/str
    Temperature: 94.5°C
    Part Throttle
    Load: 18.4 %
    Speed: 51.0 km/h
    001152 - Coolant Fan Control Circuit 1
    P0480 - 009 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00000100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 152750 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 54.0°C
    Engine Off
    Load: 0.0 %
    Speed: 0.0 km/h
    Readiness: 0000 0000
    Question is: Do I need to be looking elsewhere first? Is the fan burnt out do you think? (50/50 I know, but don't want to strip it down to find it is and have no spare) does anything else need changing as well?
    Vague I know, im not very mechanically minded so please bare with me .
    The belt also knocked out the 5 flaps behind the radiator but I've been told by a mechanic it should be fine without them. Plus they're the least of the problem at the moment
    Thank you
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    27,043
    Remove the belt stuck around it & test again, but its more than possible it is burnt out.
    rizzini7's Avatar
    Jun 2011
    722
    Right I'll order a new fan from TPS an hope I can return if its not needed. Then at least if its burnt out I have the new one ready. There's no way the belt is coming out while its fitted.
    rizzini7's Avatar
    Jun 2011
    722
    Wow, £147+vat. Lets hope the old one works
    27,043
    Yes but savings on the labour will certainly make the fans cost less heavy & lets be honest £180 isn't allot of money for a rad pack.
    rizzini7's Avatar
    Jun 2011
    722
    Wasn't a rant mate. Just bit depressed at the moment misses power steering rack has gone wrong as well. Bad couple of weeks.
    I just asked Tps for new electric fan so assume it comes with all I need. Didn't bother with the flaps as they where £100+ as well. I always by genuine Audi so expect these things I suppose. Anyway the GSF fan was £105 and looked like it was just a fan with two bits of wire.
    On another note Nigel when doing a full scan it gets so far and crashes telling me to check connection etc.. And won't continue?? Yet when coding etc its fine? I'm using a new genuine cable.
    Dodgy laptop USB (laptops had so stick) or port on car?
    27,043
    I didn't read it as a rant either lol.
    I would test on another port or laptop 1st, do a port test under options, move the usb connection about when scanning see if this has any effect, check for updates.
    rizzini7's Avatar
    Jun 2011
    722
    That's alright then lol.
    Yeah I'll try someone else's car at some point then. Was planning on just getting a netbook soon anyway. Find a 17" bit to big to sit in the car with.
    rizzini7's Avatar
    Jun 2011
    722
    Fan replaced and was working when I looked last night. However now no aircon. Switches to Econ
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BL
    Component: A4 Klimaautomat 2832
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6CD18BDC1C839378EC3
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    30-00 - Open or Short to Plus
    01317 - Control Module in Instrument Cluster (J285)
    79-00 - Please Check Fault Codes
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 951 F HW: 8E0 920 951 F
    Component: KOMBI+WFS 4 H12 0110
    Revision: 0110 Serial number: 00000000000000
    Coding: 0023401
    Shop #: WSC 00654 512 00000
    VCID: 2D5746D8B7195A70BBD
    1 Fault Found:
    00779 - Outside Air Temp Sensor (G17)
    010 - Open or Short to Plus
  1. Big electric fan relay ?
    By prodrive in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th September 2008, 10:53
  2. Flat battery and electrical drain....HELP!
    By CJA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 09:08
  3. STEERING / ELECTRICAL PROBLEM!?!??! HELP NEEDED!?!?!?
    By Baker21 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th June 2007, 14:20
  4. audi a6 ecu problem? water in the electrics? any help out there?
    By darby7 in forum General Technical / How To
    Last Post: 20th July 2005, 10:31
  5. 2.8 30v Electric Fan...
    By abeabt in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st October 2004, 08:49
