AH FabricationsVolks Autos
Results 1 to 16 of 16
    Feb 2013
    Wiltshire
    346
    Done today something EVERYONE should go do!
    Ok, so by now you probably realise I am doing a ton on the car at the moment. So I was checking all the wheel bearings (they seem pretty good at the moment), I decided to rotate the wheels. Well worth doing that guys.
    However, that wasnt the most important thing. When I had the car up a couple of days ago on the lift, I removed all the under plastics and undersealed the car before putting the plastics back on. Today, i decided to get into the engine bay and check it out. I pulled out the battery and removed the plate that it sits on (two nuts). I also removed all the pollen filter box plastics (3 nuts). Underneath the battery was a HUGE amount of dirt, leaves, twigs, and general crap. It took me about 2 hours to fully clean using the shop air, a dyson, and a load of other tools. There was very minor surface rust in a few small places, so gave that all a good sorting and used the remaining underseal in the compartment. I was suprised that there wasnt any corrosion or rot.
    Tomorrow, might look at getting the headlights out and de-tangoing!
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Was a thread about the chamber filling with water and leaves recently. So when I had a new battery fitted the other week I pushed the rubber drain bung under it out.
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    yes there was a recall to sort that
    did you pop the bungs out aswell very common on the B6 B7 for them to block and cause problems under the pass seat
    Med performance's Avatar
    Mar 2012
    Wrexham
    Follow Med performance On Twitter
    Had the same problem on my mates b6 under the passenger seat
    Feb 2013
    Wiltshire
    346
    No, but I can go do that pretty quickly. What was the issue with the passanger seat?
    bez101's Avatar
    Jul 2008
    8,525
    water gets in runs under the carpet and ruins the ccm under pass seat
    Feb 2013
    Wiltshire
    346
    ah, well thank fk thats not happened! Will pop out hte battery tomorrow and pull out hte bung. Is there another under the ecu box?
    Oct 2012
    492
    i had this on my vw passat very comon problem and well covered on passat forums my rear passenger footwell was 1" deep on top of the carpet and that means its a lot deeper as theres a recess underneath the floor with comfort control unit in which corodes one of the first signs is alarn going off all the time for no reason it was a nightmare as i couldnt lock the car without setting the alarm so ended up having to leave it unlocked for weeks while i sorted it, the water builds up in the plenum under winscreen due to blocked gromets (best just to push them out alltogether) then it gets to the level of the pollen filter or sloshes on it while driving and runs down the ventilation pipe and that channels it to under the passenger seat , when i was looking into it people were so desperate they were drilling holes in the floor to release the water
    Tim@G's Avatar
    Apr 2013
    26
    I had this in my old b5.5 saat estate. Water and slimey gunk in the plenum. Apparently was a recall at vw and all they did was push the bungs. I pushed mine out and run loads of water through to clear the gunk out. When I moved the car there was 2 quite big lumps of sludge on the driveway
    Didnt realise my b7 was susceptible to the same problem. Ill check it 2morro I think.
    Good call
    May 2013
    60
    any one got any pics of where this is?
    Feb 2013
    Wiltshire
    346
    I know one for sure. If you pull out the battery, there is a bung pretty much under that. You may not see it if its covered in crap, but its pretty visible. Not sure if there is another. Will be looking today.
    May 2013
    95
    yes there is to the left of the battery by the big round thing ( not sure whats its actually called) - theres a webpage about it (though on a Passat - but they are basically the same layout I believe)
    Interior leaking | veedoubleu dot com
    Feb 2013
    Wiltshire
    346
    Quote Originally Posted by MattUK View Post
    Nice find! The layout is near identical to my s4, so this will be relevant to us. I would advise (if possible) that this becomes a sticky?
    Jul 2013
    Cambridgeshire
    279
    Would this kind of thing have any effect on an A3 8P?
    2007 A3 S Line Quattro 170 TDi
    V.A.G.erbond's Avatar
    Spooling
    Nov 2012
    Leeds
    131
    I've got 2 goldfish in mine I will remove bung and put fish in bowl. Always wondered why I had water leaking from drivers arch when I stop driving now I know. Thanks
    Spooling
    Nov 2012
    Leeds
    131
    Drained the tank yesterday lol
  1. Few jobs done today...
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2010, 22:31
  2. Running on 3 cylinders, everyone should carry a spare coil.
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd January 2010, 17:52
  3. Another Joey Mod done today...
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th June 2009, 13:53
  4. JBS Custom Code Remap & Filter Done Today
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2009, 20:56
  5. ...And what have you done today???
    By Justincredible in forum Photography & The Digital Darkroom
    Last Post: 7th July 2007, 18:27
